Question about Hampton Technologies Brinks Timer
Help me work this thing please?
I follow the instructions which came with it but I can't get the light to turn on and turn off at the times I set.
  • brneyesdms
    brneyesdms Dec 01, 2012
    I have tried many Brinks timers especially at holiday time. I set the on off times and plug the timer in and they should not be on yet, but they are, and then they don't shut off at all. Please help!
  • Gene Haynes Dec 01, 2012
    Is this a digital or analog timer? Describe timer in detail so I have start-point for helping. Also I suggest not using lesser quality Brinks timers, and suggest Intermatic, Woods, GE, in that specific order ... because these timers have warranty service through known companies, and they make good product.
  • Hampton Tech... Master
  • 5,391 Answers
Brinks analog plug-in-outlet timer??
Copy following link for instructions how to set timer by experimenting with features:
http://waterheatertimer.org/How-to-set-timers.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Nov 02, 2012
Testimonial: "I am 99.9% sure this worked. Thanks again Gene!"
  • Jenni Ferguson Nov 03, 2012
    Thanks Gene. I'll give it a try.
6ya staff
SOURCE:
Laptop wont boot up, black screen, has power
You didn't post the Make, Model of Laptop or the OS you are using. I'll use a Win 7 solution. Boot the Laptop, open the Control Panel, select Power Options, set to High Performance, select Change Plan Settings, set SLEEP to Never, select Change Advanced Power settings, go through the settings , set SLEEP and Hibernate to Never, Power buttons and Lid to shut down. Always shut down and unplug your laptop when not in use to prevent damage from power surges and possible Fire hazard IF the battery malfunctions. A reboot every day will reset the computer.
Apr 21, 2013 | Computers & Internet
Westinghouse outdoor timer with 6 outlets instruction manual
1) Copy following link to help identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
2) After viewing link above, add a comment with clear detail about timer
Dec 22, 2012 | Hardware & Accessories
Oven doesn't heat up and no light symbol shows up on the indicator panel.
it sounds like you tod stat has gone if you turn the oven off from the mains pull the oven right out and take the lid off you will see a little black stat with two wires join then up together do not let them tuch any thing then turn the oven back on if it all works afther you put the time in you will need a new one of them ok hope i have helped you
Nov 03, 2012 | Bosch Ovens
1997 eclipse dash lights not working i know there are two fuse boxes i dont know which one o look at and which fuse it is help?
Your tail lights, license plate ights, and side marker lights are protected by the same fuse that supplies power to the dash lights. Hint: if your other lights are working, the fuse is NOT blown and you don't have to spend time looking for it.
The next thing that deserves mention is the fact that the dash lights are controlled by the dash light rheostat (dimmer switch). Make sure you don't have them turned off with the switch.
If after reading the above, you still think you need to find the fuse, it is fuse #5 (15 Amp) located in the dedicated fuse and relay box in the engine compartment. It is most likely marked "Taillight Relay".
Please also review the following articles:
Where's The Fuse?
What Else Could Be Wrong?
Sep 18, 2011 | 1997 Mitsubishi Eclipse
I have a stanley Ultra Bright LED Spotlight - I plugged it into the charger until the light turned "green". Unplugged it and went to use it and now the light flashes on & off constantly like...
Mine did the same thing so in desperation before disposing of it I did the following and it worked. I turned it on and while strobing, I locked it in place wanting to run the battery completely dead before recharging. It ran that way for about 45 seconds, it beeped and started working correctly. It may only be temporary, but worth a try.
Sep 12, 2011 | Garden
I still couldn't install it. please help.
If you're trying to install it on a PC, just put disk 1 in the DVD drive and start it & follow the instructions.
If you don't have "Auto Start" then go to "computer" & double click DVD drive icon.
Follow the instructions.
If you have questions reply here.
This is free help...please take time to rate me....good luck.
Jul 28, 2011 | Microsoft Office Professional 2007 Full...
I have a netgear wnce2001 universal internet adapter. It was previously configured to the wireless internet in home to work with Xbox. Just yesterday the WLAN line went out. Hooked ethernet and USB cable...
Improve the Fixya.com experience for everyone by voting!
The solution I'm suggesting works in my business (LAN installations) about 95% of the time. I trust that it will work for you.
Let's see if I can help you.
Begin by turning on your computer and your router
? Make sure your service provider has activated your account and services on the subscribed line. Please check with your service provider to confirm this.
? Make sure that you are using the latest drivers. You can download the latest driver from Driver Downloads Database.
? Make sure that you have entered the right username and password (case-sensitive) as given by your service provider. For example, in Australia: user@bigpond; in NZ: user.name.xadsl@xtra.co.nz.
? Open Internet Explorer;
? Click on 'Tools';
? Click on 'Internet Options';
? Click on 'Connections';
? Click on 'Setup'
? Click on 'I want to set up my Internet connections manually . . .';
? Click on 'Next';
? Click on 'I connect through a local area network (LAN);
? Clock on 'Next'
? Click on 'Next' [This is not an error];
? Click on 'No';
? Click on 'Next';
? Click on 'To connect to the Internet immediately . . .; and,
? Click on 'Finish'.
That should have you online. However, if it doesn't get you on line, do the following: Click on tools again. Click on 'Diagnose Connection Problems' and follow the instructions.
The last choice is to use the Setup Wizard. It seldom works for me but you might more luck than poor me. Here are the instructions:
The Connect to the Internet wizard will guide you through the steps of setting up an Internet connection.
Open the Connect to the Internet wizard by:
• Clicking the Start button Picture of the Start button
• Click on Control Panel.
• In the search box, type network,
• Click "Network and Sharing Center"
• Click Set up a new connection or network
• Then double-click "Connect to the Internet".
All the best
Ben
Jun 18, 2011 | Computers & Internet
Hi I have a blueant z9i bluetooth and I can't seem to pair it to my phone I have a motorola defy could someone please help i've followed the instructions several times but nothing. Thank you Cherie
Have you tried to put your headset in pairing mode first? In order to do it, starting with it turned off, press and hold its multi-function button for some 6 seconds, until its indicator light turns solid blue, and, then, starts flashing. It is in pairing mode now. Then, bring your phone close to it, turn it on and go to 'Menu > Settings > Wireless & networks' and tick the 'Bluetooth' checkbox. Then, tap 'Bluetooth settings > Scan for devices'. After a little while, your headset should appear on the found devices list (if not, slide the screen down). Tap over it. They should pair with each automatically. Otherwise, if a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros).
Hope it works for you.
Anyway, please, let me know if I can help you any further.
Oh, if your headset's user guide happens to be missing, feel free to download it from this location.
Regards, Carlos
Apr 27, 2011 | Motorola Mobility Defy Cell Phone
LCD HDTV turns off, displays lines & static w/ loud noises
check in your manual and follow instructions on updating the software. you download the file to computer then move it to a memory stick (USB), then simply insert it into the tv
Mar 01, 2010 | Televison & Video
Hampton Technologies Brinks Timer Logo
534 people viewed this question
Top Hampton Technologies Hardware & Accessories Experts
Gene Haynes
Thomas F. Schneider
Are you a Hampton Technologies Hardware and Accessory Expert? Answer questions, earn points and help others
