Bissell Lift-Off Revolution Pet Vacuum Cleaner just shut off while I was using it. I tried a different plug. Is there a reset button or do you think the motor burned out? Fix or replace?
Probably a hose clog. Check the hose on the back of the cannister. Most likely clogged where it attaches to allow debris into the cannister. If cannister is not filling up, that's a sure sign. To remove from top of back of cannister, just turn the ring on the end of the hose to release. Take it outside and push a long thin object through it to force out the clogged hair or debris. The motor is designed to shut off the vacuum cleaner for 30 minutes when this happens to avoid burning up your motor.
I assume you mean the vacuum motor isn't running, could be the switch, cord or the motor, If you are able, I would start with the switch.
Loved my vac for the first 4 months...now I vacuum 1/2 of my living room and it shuts off. I have to wait an hour to use it again. Why is it doing this??? Try to fix or replace???? HELP
same problem with the 3760-1
Vacuum keeps overheating and shuts off. I have cleaned all the filters, etc and it still does it.
