When attempting to increase the temprature of the oven for a meal (350 to 450), the oven temp. did not increase. The "PreHeat" button was on, but nothing happened. The oven can go up to 350, but it takes 20 minutes. I've shut the power off at the breaker box and turned it back on hoping a "hard-start" would help, it didn't. Any solutions?
If you have multiple elements it is possible that one may be burned out and limiting the high end of operation.. Check all to make sure that none is open and replace as necessary.
Check attached site for parts and prices. If you can get the part number it is possible for you to be able to get it on ebay for less money. No harm in checking. Search Over 2 1 Million Appliance Parts
SOURCE: Gas oven not heating to temp
The fault is either the capillary has fallen away from back or it is a faulty thermostat.
Regards
Advisor
SOURCE: Oven appears to start, takes forever to preheat,
This is what I would do: I would unplug the range and connect my test cord to your range cord. I use an ammeter along with my test cord to read the amp draw of the bake ignitor. If it cannot get above 3.5 amps I know the ignitor is bad or weak. Since the oven is working that means there is a good circuit. In order for the safety bi-metal to open the amp draw must reach 3.5 amps or better. So to me I am thinking bad ignitor. To get to it I remove the door oven racks and bottom, I then remove the flame spreader and unplug the quick connect to the ignitor. I remove the burner and ignitor and replace the ignitor on a work bench. I am too old to be bending over and trying to do any parts replacement inside an oven. LOL. I have a training film which shows how the silicone carbide ignitor works HERE. Post a model number and I may have a service manual, do not forget to rate the answer.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Testimonial: "This advise seems right on. Thanks for your fast and detailed advise. Steve"
SOURCE: why does it take so long to preheat.
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
SOURCE: My oven seems to take
Hi, That would seem to be longer then normal...
If
your electric oven is taking too long to heat or just not heating up
right, then check out this tip that will give more detail about your
problem.
Oven
Problems Electric Oven is Heating Slowly or Poorly
heatman101
SOURCE: We have a Whirlpool gas
Hi This means a
loose/broken wire on the oven temp sensor or the oven temp. sensor itself is
bad and should be replaced. To solve this issue test the oven temp. sensor, it
should read between 1080-1120 ohms, if the rating is more then that and the
door appears to be closing fine then it is the control board that is bad and
should be replaced. Hope this helps...please post back for further assistance.
Daniel
