Are you on mute by accident? If not your sound circuit needs repair. Or the power supply line power distribuition.Some voltage is missing to the sound circuit.
press it hard and try to vibrate the button sometimes it makes bad contact or random connection. Also try different remote or ask you cable provide for replacement.
It seems that the "Lang" button on the remote may be pressed by mistake. Try setting the language to English and see if all the channels now broadcast sound.
Are you sure this channel broad cast has sound. Please conform with some other TV. If your TV is having sound in all the other channels there is no reason for no sound in one particular channel.
I think you need to look at the sound settings. In particular the type of sound. HD channels often carry AAC sound, suitable for Dolby 5.1 and Standard Channels don't. So the sound system will switch modes when you change channels. However the receiver is not switching back to picking up PCM signals, the type used on SD channels.
To get back sound channels ect just select the channel in question press menu, select installation, select manual scan, click ok on down frequency. It'll now scan for channels when its finished exit back to normal tv viewing screen go to the end of your channel listing and the desired channel will be there with sound. This can be done on any channel with no sound by just selecting that channel following the instructions above. Hope this helps
Most of HD channel broadcast in 5.1 channel sound. Regular channel broadcast in 2.0 channel sound. You TV only have 2 speakers so you will expect the sound will be low compare with the regular channel.
Be sure the sound source has a center channel output ie. not a 2 channel source only, try the test tone setup for 5 or 6 channel balance, if no sound from the center channel still then it is looking like maybe the center channel is blown.
It worked fine yesterday. Sound on all channels. Sometimes the picture goes black on channel 6. We can get it back by going up one channel, then back to 6.
it is due to cable signal ie weak.
now there is no sound
this is due to sound section
1 loose connect in sound section
2 speaker
3 problem in sound section some part must have failed.
