Setting the picture size aspect ratio for your TV type Support SaskTel
How to set the proper shape or aspect ratio for your HDTV
https://www.xfinity.com/support/cable-tv/tv-aspect-troubleshooting
https://www.timewarnercable.com/en/support/faqs/faqs-tv/on-screeng/theguide/how-do-i-change-the-aspect-rat.html
LG Smart TV How to set the default aspect ratio
SOURCE: Aspect Ratio or Input Issue
Not sure but you might be confusing your aspect selection on your DVR with aspect selections on the tv itself. Make sure you use your hitachi remote & check all available aspect ratios. Find one that suits u best
SOURCE: How to adjust aspect ratio on Mitsubishi VS-6043 TV?
I have the same problem and the only thing I could do was to change the name of the input on your tv to pc on the menu screen and it should set it to 1080p reduced this will fit the whole picture and set your screen res on your computer to 1920x1080
hope this helps
SOURCE: cannot change aspect ratio
If you are connected to a HD cable or satellite box, the aspect ratio is set by that box. If it is set for 1080i 16:9 wide screen mode then your TV is locked at that ratio. This is good considering you have a Hi-Scan 1080i television in the Sony KP57HW40. Please take a moment to rate my answer. Thanks...
Testimonial: "Thank you very much. That answers the question. "
SOURCE: convergance on big screen won t move from left to
Hi my name is Roety,
I can help you with your issue ,
A repairman will charge about $350-$400 to replace the convergence ICs for you.
Do it yourself repair is very technical and could cost more in the long run.
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
what brand tv? most ptv's in digital mode will not allow for aspect or format change once a signal has been selected. good luck with the u-verse.
