The bios keeps track of all mechanical s pre-boot and post-boot. Beeps most generally mean a bad stick of ram or the ram is not seated firmly in the slot. The other issues are bad CPU or the CPU fan has stopped and the bios shuts the pc down in either case.
The Beeps are a beep code 4 means you have a ram read/write failure. Or a possible motherboard failure in that case you will need to contact Dell or replace it yourself.
Windows won't start up? Well, try this Download Tenorshare Data Recovery from its offical site and install it. Burn it into CD/DVD, or USB flash, put into the computer you need to repair, Bios setting.It can make sure your important data will not lose.Best of luck Related: windows won't start
Continuse beeping POST code usually RAM or video problems. The problem maybe the RAM, it is faulty or just needsreseating to make proper electrical contact. Reseat the RAM and then boot up your laptop. If it still does not boot up thenremove the RAM module/s and take them to your friendly computer repair shop andget them to test the RAM for you.
check FAN on CPU. Check also the radiator on the CPU. If you can - remove CPU and check the paste between the CPU and radiator - apply new paste, assemble back the CPU and try again.
hi repeat beeps is definitely a RAM module issue. ry reseating (installing) one RAM at a time... assuming you have two module sticks. try inserting one only, boot up system and see if it works without beep issue. if it doesnt beep, remove that module and reseat the second one alone. boot up system. if that one works as well, then these two modules are NOT the same maker, part number. if they both work independantly, then the RAM together are not compatible. both RAM modules must be identical (maker, part number, etc) to avoid issues
