Washing Machines Logo
Posted on Oct 31, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore washer model #111092581200 won't stop filling and won't agitate
Richard Roth
Level 3:
Top Expert:
  • Washing Mach... Master 9,472 Answers
  • Posted on Nov 01, 2012
Richard Roth
Level 3:
Top Expert:
Answers
9472
Questions
Helped
2628504
Points
28464
Please recheck that model number. It is coming up as a microwave.
5 Related Answers
Anonymous
  • 7 Answers
  • Posted on Feb 02, 2009
SOURCE: Kenmore 90 Series Washer
Kenmore 90 series model 110.28912791 stops and wont spin
Anonymous
  • 2992 Answers
  • Posted on Apr 25, 2009
SOURCE: washer fills with water then stops, won't agitate or spin
There are two possible causes. The most likely cause is the lid switch, which is supposed to keep you from sticking your hand into the moving basket. On many washers this only keeps the machine from spinning, but on other models it prevents agitating as well. The other possibility is the water level switch, but that usually causes no filling or overfilling if it's bad.
Both parts are available from Sears (www.searspartsdirect.com) and many other online sources. (I normally use the Sears site to find a part number if I don't already know it, then search for that number on Google. It's a great way to find good prices on more costly parts.) There are also a number of sites with detailed information about how to remove the cabinet to get at the parts if you want to try doing it yourself. Replacing these parts is pretty simple if you're comfortable with a screwdriver and have some mechanical ability.
If you'd rather have someone else repair the machine, this would normally be about a 1 hour plus parts charge for an appliance technician. It isn't time for a new washer yet.
Anonymous
  • 99 Answers
  • Posted on Jun 11, 2009
SOURCE: Washer fills but will not spin or agitate? 1 year
Check waste hose not pushed to far down tube.This would cause same problem
Anonymous
  • Posted on Jul 04, 2009
SOURCE: Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Anonymous
  • Posted on Jul 23, 2011
SOURCE: WASHER FILLS WITH WATER, THEN WON'T AGITATE.
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Kenmore washer won't spin or agitate. Sounds like it wants to but can't.
Does the washer fill with water then stop and hum? The problem may be in the timer or processor or it could be the switch that confirms the lid or door is closed.
2helpful
Kenmore washer 90 series continue to fill w/water. Load size won't stop the fill... had to shut off water source. won't get to agitate phase... just want to stay at fill stage... can drain, spin,...
Sounds like the fill switch needs to be replaced. A good way to test it is to set your machine on low fill and see if it fills past 3/4. If it does, it's the fill switch.
2helpful
I have a top loading Kenmore series 80 washer. The cycle starts, agitates, but won't drain and go into a spin mode. It just stops after the agitate is done and remain full of water. It won't...
This is usually a door closed switch that is either a bad Lid switch It is number 11 on the diagram on this page http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11024032301/0582/0153200/K0403014/00001?blt=06&prst=&shdMod=
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Leave a comment if you need more help.
Thanks for using Fixya.
33helpful
Top Washing Machines Experts
john h
