Panasonic Viera TH-50PZ800U Plasma TV Logo
Posted on Jan 04, 2009
My panasonic th-50pz800u won't power up. The power lights blinks 10 times then pause 10 times then blinks a again?
Anonymous
Level 1:
  • Contributor 20 Answers
  • Posted on Jan 04, 2009
Anonymous
Contributor
Level 1:
Answers
20
Questions
0
Helped
12001
Points
69
A red light blinking 10 times means that a video board has gone bad. Contact Panasonic to see if they will help you out.
  • eddiecondez Nov 03, 2016
    10blink only standby power
Wont power on red light blinks
These blinks are fault indication. From the number of blinks occurs at one time switch on, you can get an idea about the faulty section circuit inside it. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2200 posts now. All are related to electronic equipment repair help. Blinking codes to Panasonic Plasma Displays are given in detail.
Panasonic error code 001
how many times does the power light blink? Let me know and I will assist with the issue.
1helpful
Panasonic th-50pz800u shuts down and i can not turn back on, red light flashing 2 times, sometimes 10 times
Good day!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
2answers
Panasonic viera th-50pz800u won't turn on. Red power light blinks 10 times.
thats a sos error for numerous supply voltages missing. Send a email to me for assistance as I cant post the info here [email protected]
50 inch Panisonic TH-50PZ85U, wont turn on and has red light flashing 10 times
thats usually caused by a blown thermal fuse on the transformer and the 10 blinks appears. I can assist but will need to do it via email you can contact me at [email protected]
3helpful
TH-50PZ80U POWER INDICATOR LIGHT KEEPS BLINKING
Power board it dead,take the tv aparts.Check for Capacitors parts for puff up or burst open.Know how to solders?replaced these capacitors in the power board.Or replaced the whole power board.Tries Shopjimmy.com,Ebay.com.
10helpful
4answers
Panasonic th-50px60u power indicator is blinking 10 times
There are two guides, one for 10 blinks at power on:
or, 10 blinks at plug in:
23helpful
6answers
TH-42PX60U red light blinks 10 times wont come on
On a Panasonic TV the 10-blink error code can sometimes be caused by low voltage running through an HDMI cable, particularly from a Media PC or some video game consoles. Try disconnecting any HDMI cables and unplugging the Television for 30 seconds, then power it on without the cables attached.
If this works, connect the cables to the front panel (usually HDMI-3) which uses a different controller board.
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
