I print on a thicker, stiffer paper for certain tasks. Originally the CP1525 was able to pick up this paper without problems, but after a year or so is having lots of 'paper jams' where it starts to pick up the paper from the main tray but then gets stuck. I suspect that the pickup roller and associated hardware needs cleaning/replacement.
SOURCE: Kyocera FS-1920 won't pick up paper from tray
replace pick up rollers and paper tray roller. Take out paper tray and toner, lift printer so you can see underneath you should see a set of rollers its nopt to hard to get out. also in the paper tray there is a roller swop that out to
SOURCE: Doesn't Print - Says "Paper Jam"
That is the problem, machine will show printer jam if paper feed rollers fail to pick up paper when requested, your machine sounds like it needs new paper feed roller or you can clean the paper feed roller with a slightly! damp cloth.
If no jam light shows when power is turn on and machine comes to ready and then you send a job to printer and it then shows jam then it is the feed roller or sometimes the feed clutch
If on the other hand it always show jam then there is or a switch is stuck.
SOURCE: hp laserjet 8100 8150 13.1.42
hp printers typically do not have an error message to cover every known condition, thus if the printer needs maintenance in an undefined area, it will invariably indicate a paper jam. The printer usually responds to the installation of a maintenance kit which will include transfer roller, pickup rollers, and fuser.
SOURCE: Xerox 6250 - Jam at Registration Roller
Ik heb een deregelijk probleem gehad, ook bij merdere printers tegelijk. De oorzaak was achteraf logisch. We hadden een nieuwe zending briefpapier waar een bepaalde film op zat waar de printer niet tegen kan. Logisch, want het kan niet zijn dat alle 3 printeres tegelijk hetzelfde mankeren.
Ander papier erin. De eerste hoeveelheid zal nog problemen geveb tot der olletjes vrij zijn van de vettigheid.
groeten,
G.Eijken te Hoorn
SOURCE: paper jam ,no paper jam found Dell 1815dn
give this a try
alternative :
Load
a piece of thick paper, for example photo paper and press the resume
button (may be diffrent button on diffrent models) a few times to the
printer picks up the paper and puts it through the machine.
