If you take the rear cover off the inside of the freezer you can see the evaporator coils. observe the frost pattern. Light frost everywhere(NORMAL)
or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR
PROBLEM). .
if compressor is running, then you are correct in saying no point in replacing stat.
by sounds of it you have a faulty compressor fault or a syatem fault - impossible to dignose by remotely. this is not a diy job i'm afraid
I would first check to see if the evaporator in the freezer is all iced up. If it is thats whay you do not have any cooloing. And If that is the case you have a defrost problem and it is not short on gas. If you see only a few coils on the evaporator frosted up then you do have a leak in the system and my be covered under the manufactures warrenty.
I cannot find any manual or information on the 3 lights. I would assume that the green light means everything is OK, the red means current problem, and the amber means manual defrost is due.
Sorry, this is the best I can do.
Later.
