Kingston 4GB Secure Digital High Capacity Memory Card Logo
Posted on May 27, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Computer freezes with 4 mb Data Traveler
I plugged my brand new 4 MB Data Traveler (Kingston brand) into my computer this morning to download a large file. My computer became completely inoperable. My mouse was useless and I couldn't click on anthing. Booting did not help.
I had to turn every connection off for two minutes, and turn everything back on, restart, then I was able to use my computer. I have a fast new computer that does allow me to use other jump drives so I don't know why this jump drive won't work for me.
Harrie
Level 3:
Top Expert:
  • Kingston Master 6,746 Answers
  • Posted on Jan 12, 2020
 Harrie
Kingston Master
Level 3:
Top Expert:
Answers
6746
Questions
0
Helped
1283766
Points
83153
No idea what went wrong here, but when using a new USB drive (stick) first format it on the computer where you want to use it on. The best way to put there a file, is to download to your HD. When the download is ready copy the file to the external drive.
2 Related Answers
Anonymous
  • 33 Answers
  • Posted on Jan 16, 2009
SOURCE: 4 MB Data Traveler freezes my computer
Hi lassiebee,
Try the USB drive in other USB ports on the computer. Are you using a USB mouse and USB keyboard?
Kingston Tech Support
Anonymous
  • Posted on Mar 03, 2013
does not work. Kingston are the worst flash drives. That's why they are so cheap. throw that one a way and never buy a kingston again.
1helpful
My usb shows only 1.96 mb while its orignal space is 4 gb
remember that a memory device needs space in which to operate
so a 4gb stick will have less than the 4gb storage
It is very possible that there is some memory being used that results in the 1.96 remaining
one possible solution is to read the stick and see if there is any files or folders than are required and then reformat it to get back to full memory
1helpful
Kingston data treveler not format
Hi qais_baba
1...Plug your Kingston data traveler in to your computer
2...Go to desktop and open "My Computer"
3. You will see your Kingston Data Traveler listed there
4...Right click on the Data Traveler
5...Click on "Format"
This will format your Kingston Data Traveler
Please rate me
Bud
I recently bought my new kingston data traveler (usb) 2gb then i tried to put a few files when i tried to insert it again it was 8 mb only and cannot be fomatted.
> recently bought
Try it in some other computer. If it still has a problem, take it back to where you bought it, and exercise the warranty to get it replaced.
2helpful
3answers
I have a kingston data traveler 2gb DTI. i was copying movie files to my data traveler and it removed the volume label and i am not able to change it back. now I am not able to access any files. it does...
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
www.CardRecovery.com
2helpful
2answers
I can't format my 2gb kingston data traveler 2ntfs and it stores only less than 28 mb. i can only use this data traveler on my microsoft office word and excel files but about my audio files, all could be...
I have kingston datatraveler 200 (64gb) and I backum 4gb`s on that usb, but when I want to opet that, its corrupted, damaged and now I cant even format my usb.. help
Unable to enter privacy zone , kingston data traveller 2
if it is corrupt you may not be able to open it.
there are programs can help solve the problem of corruption, antivuris program, some old disc repair software, the vender may have tools to help you save the information but if all fells you may have delete all and start all over.
rodgandysr
Kingston flash 4 gb slow upload and download to my pc
is it plugged into a usb 2.0 port ? ... vista was always slow for moving files if that is what you use.... there is an update or patch for that from microsoft.
Robert
2answers
Hi lassiebee,
Kingston USB key Data Traveler 8GB doesn't work well when more than 512 MB are copied in it. Same problem with different computers (with Windows XP SP2 or SP3). Same problem when formatted with FAT32 or...
If you have not tried this already, go to control panel, click on administrative tools, then double click computer management. In the left pane under computer management, click on disk management.
Make sure your Kingston data disk is plugged in to your usb port. In the right pane you should see your flash disk represented by a white bar with blue line on top. Right-click on the white bar and select "delete partition" Once the partition is deleted, right-click the bar once again and select create partition. Once you have created this partition, you should have the use of the maximum capacity of the flash drive.
Top Kingston Electronics - Others Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Kingston Electronics - Other Expert? Answer questions, earn points and help others
