Hello
By know you should of fixed the problem .
1. keep the inside cabinet clean.
2.If the unit keeps shutting down by itself after a certain time and it is not dirty inside the cabinet .Also all the intact screens are clean . Check your Personlization settings By right clicking on your screen . then right click Screensaver and then power settings . Then check to make sure all the settings are turned off unless you want the computer to shut down after a certain amount of time
1) Bad Power Supply. 2) Bad Radial Aluminum Electrolytic Capacitors on the motherboard,http://capacitorlab.com/visible-failures... 3) Computer is dirty inside. Processor has been overheating, and turned off. So many times, and it won't turn on again (BIOS rules this), until the problem is corrected. Power Supply can be checked with multimeter. ($5 to $12) Check the 3 main voltages coming out of the Power Supply. [ 3.3 Volts DC, 5 Volts DC, and 12 Volts DC. In comparison two D cell flashlight batteries store 3 Volts DC. Dangerous voltages are contained in the metal case of the Power Supply ] Or use a KNOWN to be good, Compatible power supply borrowed from another working, (Unused?), computer, for a test unit. Post back in a Comment if you would like guidance, and post the desktop computer manufacturer name, (LG?), plus the model number. (Back of computer next to the Windows product key, or up on the side of the computer tower. Model Number. MDL )
