Cars & Trucks Logo
Bob Martin Posted on Oct 30, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to change time and date etc on the clock - Cars & Trucks
Marvin
Level 3:
Top Expert:
  • Cars & Trucks Master 85,242 Answers
  • Posted on Oct 30, 2012
Marvin
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29053912
Points
266281
That info is in the owner manual. If you don't have one check Here to see if you can download one.
How doI set the clock
Setting the Time (Without Date Display) If your vehicle has an AM/FM base radio with a single CD player and preset buttons numbered one through six, the radio will have a clock button for setting the time. You can set the time by following these steps: 1. Press the clock button until the hour numbers begin flashing on the display. Press the clock button a second time and the minute numbers will begin flashing on the display. 2. While either the hour or the minute numbers are flashing, turn the tune knob, located on the upper right side of the radio, clockwise or counterclockwise to increase or decrease the time. Instead of using the tune knob, you can also press the SEEK, FWD (forward), or REV (reverse) buttons to adjust the time. 3. Press the clock button again until the clock display stops flashing to set the currently displayed time; otherwise, the flashing will stop after five seconds and the current time displayed will be automatically set. To change the time default setting from 12 hour to 24 hour, press the clock button and then the pushbutton located under the forward arrow label. Once the time 12H and 24H are displayed, press the pushbutton located under the desired option to select the default. Press the clock button again to apply the selected default, or let the screen time out. Setting the Time (With Date Display) If your vehicle has a radio with a single CD player or a CD with DVD player, the radio will have a clock button for setting the time and date. To set the time and date, follow these instructions: 1. Turn the radio on. 2. Press the clock button and the HR, MIN, MM, DD, YYYY (hour, minute, month, day, and year) will appear on the display. 220 3. Press the pushbutton located under any one of the labels that you want to change. Every time the pushbutton is pressed again, the time or the date if selected, will increase by one. • Another way to increase the time or date, is to press the right SEEK arrow or FWD (forward) button. • To decrease, press the left SEEK arrow or REV (reverse) button. You can also turn the tune knob, located on the upper right side of the radio, to adjust the selected setting. The date will not automatically display. The only way to see the date is by pressing the clock button when the radio is on. The date with display will time out after a few seconds and go back to the normal radio and time display. If your vehicle has a radio with a six-disc CD player, the radio will have a MENU button instead of the clock button to set the time and date. To set the time and date, follow these instructions: 1. Turn the radio on. 2. Press the MENU button. Once the clock option is displayed. 3. Press the pushbutton located under that label. The HR, MIN, MM, DD, YYYY will appear on the display. 4. Press the pushbutton located under any one of the labels that you want to change. Every time the pushbutton is pressed again, the time or the date if selected, will increase by one. • Another way to increase the time or date, is to press the right SEEK arrow or FWD (forward) button. • To decrease, press the left SEEK arrow or REV (reverse) button. You can also turn the tune knob, located on the upper right side of the radio, to adjust the selected setting. The date will not automatically display. The only way to see the date is by pressing the MENU button and then the clock button when the radio is on. The date with display will time out after a few seconds and go back to the normal radio and time display. 221 To change the time default setting from 12 hour to 24 hour or to change the date default setting from month/day/year to day/month/year, follow these instructions: 1. Press the clock button and then the pushbutton located under the forward arrow label. Once the time 12H and 24H, and the date MM/DD/YYYY (month, day, and year) and DD/MM/YYYY (day, month, and year) are displayed. 2. Press the pushbutton located under the desired option. 3. Press the clock or MENU button again to apply the selected default, or let the screen time out
How do I change my i30 clock to 24hr
Try the owners manual?
I don't know what your dash layout is but you must be able to set the clock time.
If the clock display is in the hooded centre dash panel press set for more than one second to enter clock/date menu then press set briefly to move through the settings. Try pressing H and M at the same time to change from 12 to 24 clock.
How do i change the time and date on citroen xsara piccasso o2 model ?
look at the dash board in front of you the left button where the speedo is push and hold clock will flash use the right hand stalk to rotate the time and date
HOW DO I CHANGE TIME AND DATE ON A PEUGEOT 307 SW
ON THE CENTER DISPLAY HAVE TWO BOTOMS PLAY WHIT THEM AND YOU SEE
After battery change on my 2001 avalon the time/date reset to default even I set the time/date correctly then turn off the ignition and turn back on again then the time/date reset to default again .
If some connections were changed then the ALWAYS ON +12 volt to the clock circuit back up is not powered all the time . check if while the battery was changed if there was any link that was disconnected that is the continuous supply to the clock.
2helpful
How do you change the clock on a 2009 Chevy cobalt.
Setting the Clock Without Date Display AM/FM Base Radio with a Single CD Player
To set the time:
  1. Turn the ignition key to ACC/ACCESSORY or ON/RUN. Press to turn the radio on.
  2. Press until the hour begins flashing on the display. Press a second time and the minute begins flashing on the display.
  3. While either the hour or the minute numbers are flashing, turn to increase or decrease the time.
  4. Press again until the clock display stops flashing to set the currently displayed time; otherwise, the flashing stops after five seconds and the current time displayed is automatically set.
To change the time default setting from 12 hour to 24 hour, press the button until 12H or 24H is displayed. Once 12H or 24H is displayed, turn the knob to the desired option to select the setting. Press the button again to apply the setting, or let the screen time out.
With Date Display Radio with CD (MP3) and USB Port, and Radio with Single CD (MP3) Player
To set the time and date:
  2. Press and the HR, MIN, MM, DD, YYYY (hour, minute, month, day, and year) displays.
  3. Press the softkey located below any one of the tabs that you want to change.
  4. To increase the time or date do one of the following: • Press the softkey located below the selected tab. • Press SEEK, or FWD. • Turn clockwise.
  5. To decrease the time or date do one of the following: • Press SEEK or REV. • Turn counterclockwise.
The date does not automatically display. To see the date press while the radio is on. The date with display times out after a few seconds and goes back to the normal radio and time display.
To change the time default setting from 12 hour to 24 hour or to change the date default setting from month/day/year to day/month/year:
  1. Press and then the softkey located below the forward arrow label. Once the time 12H and 24H, and the date MM/DD/YYYY (month, day, and year) and DD/MM/YYYY (day, month, and year) displays.
  2. Press the softkey located below the desired option.
  3. Press again to apply the selected default, or let the screen time out.
How do I reset the clock on a 2008 Impala, and 2008 Accord? I can't find the manuals
For the Impala:
This type of radio has a H (clock) button for setting the
1. Press the H button until the hour begins flashing on
display. Press this button a second time and the
minutes begin flashing on display.
2. While either the hour or the minutes are flashing,
turn the f (tune) knob, located on the upper right
the tune knob, you can also press the SEEK arrows,
\FWD (forward), orsREV (reverse) buttons
to adjust the time.
3. Press the H button again until the clock display
to 24 hour, press the H button and then the
Once the times 12H and 24H are displayed, press the
select the default. Press the H button again to apply
With Date Display
time and date.
2. Press theHbutton and the HR, MIN, MM, DD,
selected, increases by one.
press the right SEEK arrow or\FWD button.
sREV button. You can also turn the f (tune)
date press the H (clock) button while the radio is
1helpful
How to reset the clock on dash
I'm thinking that your talking about the VIC is the Vehicle Information Center... Its the display unit between the radio & the ashtray.
You have to hold the "set" button while the time/date is displayed. Use the set button to change each section, then select to cycle through.
Hope helps with this.
Change date & time in the computer BMW530i 2002
If you also have the analog clock in your gauge cluster change the time on it first and the computer shoul set itself after you have changed the time on the analog clock.
7helpful
2answers
2002 Audi A6 - clock adjustment
I have the same car, and also don't have a manual. I found out to set the clock, pull lightly on the dial in front of the display. The display will blink and all you need to do is twist slightly to set time, date, etc. Hope this helps! How do you love it so far??
Priscilla
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
