Epson Stylus CX6600 All-In-One InkJet Printer Logo
A
Anonymous Posted on Oct 30, 2012
Unlock carriage unit in epson cx5500 - Epson Stylus CX6600 All-In-One InkJet Printer
5 Related Answers
Anonymous
  • 27 Answers
  • Posted on Nov 08, 2008
SOURCE: EPSON CX7300 locked carriage
hiii...
you carriage is jam at the purge unit..u need to open all u printer cover..try to move the carriage slowly..couse it may can damage purge unit..
Anonymous
  • 1463 Answers
  • Posted on Jan 25, 2009
SOURCE: I am trying to find the software of Epson stylus CX5500 printer
hi bunrany
if you go to Epson Driver Download you will be able to download the drivers you need .
riz.
Anonymous
  • 186 Answers
  • Posted on May 22, 2009
SOURCE: software scanner of epson stylus cx5500
I will give you a easiest way for finding the drivers that you needforyour hardware.Just download the software named drivermagician.Installit and it will search for the drivers that is notinstalled for thehardware you have through internet and will downloadit for you.
here is the link for that software
http://www.ziddu.com/download/4569239/Driver_Magician_3.42.zip.html
aicaxz
Anjazmoro Wicaksono
  • 511 Answers
  • Posted on Oct 19, 2009
SOURCE: How to reset 73/91 Cartridges for Epson CX5500
SSC utility is used for resetting waste ink counter, not for ink level counter (chip at ink tank). If you wish to reset ink level counter (chip), you must use hardware resetter, or use CISS chip with autoreset function.
Anonymous
  • 1188 Answers
  • Posted on Dec 16, 2009
SOURCE: how to remove catridge from epson stylus cx5500
Take a look, shows it in both the quick start and user manual links:
http://support2.epson.net/manuals/english/spc/styluscx5500/pdf/cx5500_sh_en.pdf
http://support2.epson.net/manuals/english/spc/styluscx5500/use_g/index.htm
CANT PRINT EPSON STYLUS cx5500 SERIES
Remove your printer from the PC and uninstall the printer software. make sure there is no other conflicting softwares in the pc specially recently downloaded programs. If so uninstall them too. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Now make a test to see if the PC commands the printer. If there is no response, check the head assembly/ ink carriage to be struck or out of alignment. Check for possible realignment of any of these mechanical problems., jammed roller or head drive.
If not check the power supply unit for sub voltages to the main board. If all these test ok , the main board can be defective
4helpful
To realign my cartridge carriage i need to press "ink button" cant find it epsoncx5500
Turn on printer, and just unplug power while carriage moving. Unplug USB. Then move carriage by hand.
1helpful
Epson cs5500 scanner software wont work
try downloading the latest drivers from epsons website. if coping is working and printing is working, it sounds like a software problem. Its possible there is a bug in the scanner part of the drivers.
4helpful
3answers
14helpful
3answers
Installation of cx5500 epson no installatin cd
You can get the software for the Epson Stylus CX5500 from here:
http://tech.epson.com.au/downloads/category.asp?id=styluscx5500&EmailAdd=&CanEmail=&SelOS=Y&MetricIDReturned=2745207&sCategory1=Multi_Functional
Just choose your operating system and press Search, then Continue on the next page.
Fixya!
Chris (ziraffa)
hiii...
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
