I am receiving an error regarding the waste ink tank. The Error Code is E/2/7. Is there a way I can fix this on my own? Thanks.
I wrote this on another help site I thought I'd post it here.
Let me just say this I have had many dealings with this printer type.
Before we start what needs to be done is that the two little filters under the printer carts need to be cleaned as well as the two little rubber parts housing the filters; wash these in water (after taking out of the printer) the filters should come up white-ish.
Also make sure that while you have the filters out to clean in and around that area with a cloth / tissues something to absore excess ink. After you clean this however you still need to service resert your printer.
The method for doing so is worded very badly on alot of sites so I will explain my way.
(1) have your printer power down ie. off, just to make sure pull the plug out and wait 10 seconds.
(2) plug printer back in, now Hold down the Stop/Reset button don't let go.
(2a) push and hold the on/off button
----at this point both fingers are holding down the buttons.----
(3) take your finger of Stop/Reset, pause maybe a second now press stop/reset button once and then press again and hold.
--- both fingers at this point are hold down both buttons----
(4) take your finger off on/off and now finally take your finger off stop reset.
---wait for the printer to go into its service mode ie. wait maybe 30 secs a min whatever till the printer carage has moved back into ints original spot.
---after this has occoured you should be able to press Stop/reset to cycle though the options
each time you press Stop/Reset Alarm and on/off should alternate lighting up. Hope this helps.
0 time Green Power off
1 time Orange Service pattern print (auto teste)
2 times Green EEPROM print (dados da EEPROM)
3 times Orange EEPROM reset (EEPROM reset)
4 times Green Waste ink counter reset (Absorvente reset)
Also google MPtool and downlad that this can reset your ink carts to full again, and can help with other errors, BUT your printer needs to be in low level mode. Google that I can't find that at the moment.
Hope this helps good luck
Following is the procedure to reset the waste ink counter for the Canon Pixma MP150 1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button. 2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button. 3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection) 4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset. The number of the Reset button pressing LED Function Remarks 0 time Green Power off 1 time Orange Service pattern print 2 times Green EEPROM print 3 times Orange EEPROM reset 4 times Green Waste ink counter reset 5) Turn off the printer.( it must be turn off) then turn it on again.
When it shows 0 just press Stop/Reset 4 times. Then turn the printer off (you may have to press power button twice to turn off) and back on. That's all.
I still have that problem
SOURCE: I have a Cannon Pixma MP150 printer. I am
Hope this helps. Please rate my response.
Thanks.
Have a good day.
This was exactly what I needed! Thanks!
i have a canon pixma mp 150 and an 27 error plese help
I took out the old ink and put in new ones and the alarm light turns on and reads E 27
when i on my printer, error code is E/2/7. can u help me?
give me the best solution? Thanks.
Screen warning that MP 150 waste ink tank is nearly full
My Canon pixma MP150 is showing E27 error. Can you give me some advice about this problem? Thank you...
My Canon PIXMA MP 150 is showing E8 error "waste ink tank is nearly full". The instructions said to press the start button to resume printing - I did and nothing happened. How can I solve this problem?
error 2,7
Error 8 Waste Ink tank nearly full
I HAVE E2 ON IT HOW DO I GET IT OFF
Error code E27
error message E2
printer errror message E2
I have the same problem and as hard as I try following the reset instructions I can not reset E27
I have gone through the resetting procedure and the E27 disappeared. However, as soon as I turned the printer off and on again the problem reappeared! Help me please. This happened every time I reset it.
Tech-boy Sean
Sorry, my nick name should be Tech-Boy Sean. I missed off the last letter of my name.
Error Code E27
i HAVE THE SAME PROBLEM E/2/7/ ALARM, HOW CAN i FIX THIS PROBLEM.
error e 27
Says that the wast ink absorber is full. How do I replace it?
Waste Ink Conatiner Full. Help
the ink absorber is ful, error E2-7
iHAVE THE SAME PROBLEM E27
i tried the procedure described above, but i have problems at the step 1 and 2... WTF ? although im a specialist... i think most people will buy another printer when this happend...
waste ink absorber full how do i reset
waste ink tank
