SOURCE: Not getting cool enough
this sounds like a compressor problem. if the outside coils are getting hot (and properly ventilated) but the inside of the unit is not getting cold then the heat is coming from the compressor.
SOURCE: Dometic Top Freezer RV/TT Refrigerator
You have a switch inside the door. Turn it on this actually keeps the light on inside. This may help with your humidity problem. Also check to make sure the drain out side of the coach is not clogged you should see water coming out
try moveing the thormister up in the refer it is on the right hand side of refer inside refer box if this does not help use a fan and blow it tru outside vent on low
SOURCE: Same problem freezer is ice cold and the fridge is warm.
Make sure that the knob that controls the opening of the vent so the cold air in the freezer get to the refrigerator is operating. If it does, I don't see any reason why the refrigerator should not work.
