Wrong ac adapter used too much voltage...can i fix
SOURCE: It lights up but doesnt put out sound
A friend of mine had the exact same problem. In his case the pedal is only good for hammering nails now. If it still has it warranty I'd say look into that, if not you've got nothing to lose. Open it up, look for unattached wires. Also, try using a battery instead of an AC adapter..
SOURCE: Digitech RP3 Guitar signal processor only lights up.
Check that connectors are seated AND the input and output are correct.
Sometimes1/4 inch plugs are not seated correctely. The power adapter plugs are notorious for not making contact.
SOURCE: i hav a digitech rp500 and my power adapter broke
It is likely the adapter is underpowered for the pedal. Get the correct adapter .
