creating data accounts:
Steps:
1. Open Services Menu.
2. Open Data Account.
3. Open GPRS.
4. Create/Edit Data Account and enter the following values:
For Globe MMS Data Account:
Account Name: GlobeMMS
APN: mms.globe.com.ph
User Name: leave it blank
Password: leave it blank
Auth. Type: Normal
For Globe GPRS Data Account:
Account Name: GlobeGPRS
APN:
http://www.globe.com.ph
Auth. Type: Normal
For Smart MMS Data Account:
Account Name: SmartMMS
APN: mms
Auth. Type: Normal
For Smart GPRS Data Account:
Account Name: SmartGPRS
APN: smart1
Auth. Type: Normal
5. Save the Data Account.
Configuring WAP/GPRS/Internet Services Using the Data Accounts
Created
2. Open WAP.
3. Open Settings.
4. Open Edit Profile.
5. Create/Edit a Profile and enter the following values:
For Globe GPRS Profile:
Rename Profile: myGlobe GPRS
Homepage:
http://www.globe.com.ph/globe.asp
Data Account: GlobeGPRS (this data account is the one you have created)
Connection Type: HTTP
Proxy Address: 203.177.042.214
Proxy Port: 8080
Username: leave it blank
For Smart GPRS Profile:
Rename Profile: SmartGPRS
Homepage:
http://wap.smart.com.ph
Data Account: SmartGPRS (this data account is the one you have created)
Proxy Address: 010.102.061.046
Proxy Port: 8080
6. Save the Profile.
7. Activate the Profile.
8. WAP/GPRS/Internet services now ready to use. In case you encounter
errors, double check the Data Account and Profile created. In some cases
you need to restart the phone.
Configuring MMS Using the Data Accounts Created
1. Open Messages.
2. Open MMS.
3. Open Message Settings.
4. Open Server Profile.
For Globe MMS Profile:
Rename Profile: GlobeMMS
Homepage:
http://192.40.100.22:10021/mmsc
Data Account: GlobeMMS (this data account is the one you have created)
Proxy Address: 192.040.100.020
Proxy Port: 8080
For Smart MMS Profile:
Rename Profile: SmartMMS
Homepage:
http://10.102.61.238:8002
Data Account: SmartMMS (this data account is the one you have created)
Proxy Port: 8080
8. MMS services now ready to use. In case you encounter errors, double
check the Data Account and Profile created. In some cases you need to
restart the phone.
This configuration is working perfectly using ZT321, Baizhao 8928 and
IPhone Clone A380 and probably will work using other China Phones.
If your SIM card is previously activated using other phones specially
those phones supported by Globe and Smart, no need to activate your
SIM. This is also valid for postpaid users since SIM cards are
pre-activated for MMS, GPRS and other services.
But if your SIM is not yet activated or never been used for MMS and
GPRS, you need to activate your SIM before you can use MMS and GPRS
services.
For Smart SIM, you can use your China Phones to activate MMS and GPRS
by simply sending/texting MMS ON / GPRS ON to 333 (I don?t know if this
number is still valid). No need to download the configuration for
Smart. Just use the configuration I?ve given.
For Globe SIM, this is a little bit harder and need some workaround. I
tried to call Globe Customer Service but they cannot activate your SIM
manually on their system and the only way to activate it is by
downloading the configuration thru text or by asking them to send the
configuration. But since China Phones are not yet supported by any
Service Provider, what you can do is to active MMS and GPRS using
another phone. Monitor until your SIM is activated then transfer your
SIM in your China Phone and enjoy surfing and sending MMS.
In another forum, they said you can try using configuration for SE
p900. I?ve never tried this but if this really works, well and good for
China Phone fanatics.
can someone help in settins mms settings
I cannot access in internet services
