SOURCE: JVC 42 INCH PLASMA POWER LIGHT BLINKING ONLY NO PICTURE
no kidding? what is the problem so prevelant in this unit? obvious design flaw.
SOURCE: hi,i have an hitatchi p50t501
The Blue Blinking Light Hitachi.
When the light blinks 4 times it means you can possibly have 4 problems with your plasma.
1. X-Sus
2. Y-Sus
3. Power Supply
4. Sdr U or D
A good way to determine if you can fix this problem yourself is if you can build a PC. If you cant this can cost you upwards of 600$ to fix.
First get a flat area and lay a soft blanket down and lay your TV down so the back is up. Then goto your PC and goto Google and type "P50T501 Service Manual .PDF" you can buy it or if you look hard enough you can get it for free. Next in the service manual it will have a diagram of the Circuit Boards and their locations. Take the back off your Plasma and check the 4 boards. Look for burn marks, cracks, smoke mark. Take your time and look closely. When you find the broken boards unplug it and take the part number and find the replacement online. Plug it in and you should be good to go.
When i had 4 blinking lights i had to change my SDR U and D boards. They cost 100's a piece for Refurbished boards. Keep in mind im a contractor not a techno geek, and i was able to diagnose and fix my problem rather easy.
SOURCE: Pioneer Plasma TV-PDP-4270HD won't turn on. TV
Try this! There should be a power button on the bottom of the panel that has to be depressed for the television to power on. It is the main power supply button and without it there is no power going into the TV.
