If your Sony tells you it is recording yet on playback there is nothing there other than a blank screen, I had this problem and this is how I solved it.
1. Clean the heads two or three times with head cleaning kit
2. Leave the tape door open, with tape out or in, and warm the camera up for about 2 hours minimum.
3. Put in a previously recorded tape and see if it will display that film. If not, repeat 1 and 2. Persevere.
4. Once Stage 3 works (you might have a few "dirty" lines on it for a few seconds, and it is playing normally, try recording.
This worked for me. The heads were dirty and the camera cold but I persevered and thankfully it is OK (but for how long?)
Hope this helps. It seems to be rooted around dirty heads and coldness.
The only way if to get an 8mm player from any friend or from any photography studios that does conversion of old tapes. These recordings can be converted only if they can play well and hopefully without deterioration due to magnettic fields and fungus. Check out on old stores or maybe some electronic freaks who would be glad to share and ,make a transfer. Use can use a good handy cam to record using the the composite signals of video and audio which can be transferred to DVD. Hope you are lucky to find one! Good day.
the error c:31:23 error pertains to one of the reel (part that turns the tape) is malfunctioning. although you can play back videos, you would definitely have issue w/ recording, rewinding or fast forwarding the tape.what you can do is to turn the camcorder off.remove the battery and ac adapter for at least a minute.insert the battery or reconnect the adapter.you can also try pressing the reset button (located near the top of the speaker, on the panel where lcd screen goes to).make sure cam is on when you do that.if still your getting this problem, service would be needed for your cam.hope this helps :)
You can set tape speed SP or LP in record mode only and can not change it in playback mode. To set tape speed, turn camcorder in camera mode and go to Menu and set SP or LP in record speed option.
Regarding no picture in playback is problem mostly of dirty / clogged video head in Sony handy-cam and can be corrected by using good quality video head cleaning tape.
As far as memory stick picture concern, I think lost pictures (42)would be in other folder on memory stick.
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times. good luck
please mark the post with a fixya
I have a Sony handy cam ccd-trv108 Hi-8 and I can not get it to play or record, everytime I insert the tape and hit play the display screen flashes c:31.22 Please help me?
