Mitsubishi WD-Y65 65" HDTV Logo
Frank Garrett Posted on Oct 27, 2012
Mitsubishi wdy65 turns off after a couple minutes red lamp light
Was watching tv when the tv randomly shut off and the lamp light flashed on red. Took the bulb thing out of the back and it looked fine so I put it back in and put all the screws and stuff back. The tv is now consistently turning on for 2-5 minutes and then turning off the picture and lighting the lamp light up with red. I've replaced the bulb twice in the life of the television and this bulb has been working for about 6 months just fine. Thanks for your help
2 Related Answers
coyotedave
  • 280 Answers
  • Posted on Oct 23, 2009
SOURCE: just replaced the lamp after 2 years. TV worked
Make sure that the lamp cage is seating well .. then make sure the door is closed properly. there is a door switch and if the door dont close right the switch may be telling the set the lamp is out.
Anonymous
  • Posted on Jan 05, 2010
SOURCE: My Mitsubishi DLP TV has a 7 month old bulb, but
take the bulb out and clean the dust on and around the fan. Doing this every 3 to 4 months will extend the bulb life. The little red lamp light that is coming on is an indicator that the bulb needs replaced. Make sure you DO NOT touch the bulb with your fingers. There is a button for reseting the bulb when you replace it. I have a 65 inch Mitsubishi DLP that the bulb just went out on. This worked for me...hope it works for you.
1helpful
RED FLASHING STATUS LIGHT
Possible lamp failure but lamp light not status should blink-I have suggestions but want you to try the self check first--if set has been unplugged plug it up and turn on and when it fails:
Mitsubishi TVtroubleshooting
Here's something that might also be useful. After you turn on the set, and getthe regular red blinky lights, hold down the Device and Menu buttons togetherfor about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filtercover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cablebetween FMT and Engine disconnected
I have a Mitsubishi WD-62725 that I purchased in February 2005. The manufacture date is November 2004. I was watching a DVD the other day and all of a sudden the picture just went black. I never received a...
It sounds Lamp got broken inside, please take out lamp from TV and check its glass tube. If found broken, replace it.
Lamp replacement procedure is written in user manual page-95, click HERE to download user manual copy if required.
Lamp is available in Part Store.
Thanks.
Samsung hls5086wx/xaa turns off at random
Go to website Encompass Electronics.com type in your model number it will list part and part number ,you can also look for Lamp on E-Bay Encompass 1-800-638-3328 Also ck Color Wheel remove lamp take a flash light to watch when you turn TV on see if the color wheel is turning if it is defective set will shut OFF. But most likely its your Lamp.
Have problems with mitsu wd-52327
check the current maybe high voltage occur or due to loose connection high amper occur.
1helpful
2answers
Has Sound but no Picture and shuts down
I have the same tv and the same problem happened to me (Actualy twice). It turned out to be the color wheel motor. thats what the clicking noise is.
1helpful
TV shuts itself off after a couple minutes of being on.
One must be very careful of the quality of the replacement lamp. Many of the cheap 'deals' on the web for replacement lamps are substandard. I always recommend that replacement bulbs be the original manufacturers bulb.
1helpful
Random, intermittant blue lines
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
33 = Air filter cover is open.
44 = DVI cable between FMT and Engine disconnected
DLP TV turning on and off automatically - Mitsubishi WD-52327
1. Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if low or missing check C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB part # 930B929001
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
