Default 4 Digit user code: 1234,0000 or 1122
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
SOURCE: mera n72 mbl bar bar heng ho raha he
Does this happen even when there is no memory card in your phone? If Yes, then it might be due to some Virus or damaged files and you will need to format your memory card and the phone. To format the phone, press *#7370# on your phone's idle screen, it shall ask you weather you want to restore it to factory settings? Select Yes and enter your phone's security code (default is 12345 unless you have changed it) The phone shall restart and now type *#7780# and follow the same process again.
SOURCE: m apane mobiel nokia 2690
Your Mobile IMEI no.353410049514692
Please use this code: 6533424705
Thanks and regards,
Pramod Kumar Bhikam
9811717015
