SOURCE: Whirlpool model LSR7233EZO / doesn't fill fully
The fill switch is a very sensitive device. You can test it by blowing into the tube, listen for the switch to click, or use an ohms tester. They are actually adjustble, the adjuster screw usually has glyptol (thread lock) on it. I would replace one before trusting an adjusted one.
SOURCE: F20 CODE Whirlpool Duet Sport Washer wfw8300sw00
Hi!
“F20” on display
(Water Inlet Problem—no water or insufficient
water supply)
Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power.
Check the following:
Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked?
Are water inlet hoses frozen?
Do rate the solution.
Thanks
Rylee
SOURCE: whirlpool washer duet ghw9100lq1
Hi. this issue is being caused by a defective flow meter. this is part of the water valve assembly but, its not integrate and it can be replaced separately without replacing the entire water valve device.
Simply replacing the flow meter will fix this issue. I have posted a link below that will allow you to purchase this part online.
CLICK HERE FOR YOUR REPLACEMENT PART.
Please rate and god bless:)
SOURCE: My Whirlpool Duet clothes washer will work for the
F20
NO WATER DETECTED ENTERING MACHINE
OR PRESSURE SWITCH TRIP NOT DETECTED.
The pressure switch is not tripped after 6 minutes.
Possible Causes/Procedure
If there is no water in the unit:
– Make sure that both valves at the water source(s) are turned
on all the way.
– Check for plugged or kinked inlet hoses or plugged screens in
the inlet valves.
– Verify inlet valve operation.
If there is water in the unit:
– Verify drain pump operation.
– Verify that the pressure switch hose is in good condition and
properly connected to tub and pressure switch.
1. Verify there is not a siphon problem.
2. Press PAUSE/CANCEL twice to clear the display. The
machine will drain for 3 minutes before unlocking the door.
3. Unplug washer or disconnect power.
4. Verify wire harness connections to inlet valves, pressure switch,
drain pump and Central Control Unit (CCU).
5. Check all hoses for possible leaks.
6. Plug in washer or reconnect power
7. Verify pressure switch operation.
8. Verify CCU operation by running a Diagnostic Test or any cycle.
SOURCE: Whirlpool Duet fills when off
It's Quite easy.
To test Inlet valve, follow the below guide :-
http://www.acmehowto.com/howto/appliance/washer/check/inletvalve.php
To test the Water level switch/Pressure switch, follow the below guide :-
http://www.acmehowto.com/howto/appliance/washer/check/waterlevel.php
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
