Where i look for it or how can i get the 30 digit activation key ?
SOURCE: cd activation key, faded on the bottom of laptop.
i dont know but u can use mine power dvd 6 key dv22636500118872
DXUNB-LH8HF-DAZHF-HDUR5-K9FPR-7E23E
SOURCE: Activation?
basically most third party softwares need to be purchased even if it`s included in your laptop.either you can try searching for a crack on torrent websites or you can try this :->
Company: (any company name)
Serial: GXUWF-M57KD-ZLV5R-34RS2-865TE-BPHSS
Note: Activate it but Do not register
SOURCE: need activation key for cyberlink power dvd 9
Normally in the program there is under "help" normally, there is a menu called "purchase" or "buy now" or something like that. Then you press on it and normally the program guide you to cyberlink purchase site where you can purchase it. Note you normally need a credit card to purchase the product.
Hope thats help good luck !
SOURCE: I can used my cd/dvd burner
Hi!
follow these steps to acquire working serial key.
1. Click this link : http://www.serials ..
on the Search box type your software version (example: cyberlink powerdvd 6 deluxe)..then click Search..
2. Select your software and version.
3. On the Type Here box...type the numbers you see in the smartserials and press the Get Serial Number..
the
list of working numbers will be listed (Note :some are not working.. so
find same version with different category..it will work too)
If you find this information very helpful..please rate this solution.. thanks..
