Hi Jose, do you have connected the card with the AM and FM antennas on your Sony HCD EC55?
If this is the case and you cannot tune in, you have problems in the tuning module
Find a specialized Sony technical service
I hope you can solve the problem
Regards Franco Dosil
Hola Jose, tienes conectado la ficha con las antenas de AM y FM en tu Sony HCD EC55?
Si es asi y no puedes sintonizar nada, tienes problemas en el modulo de sintonia
Busca un servicio tecnico especializado Sony
Espero puedas resolver el problema
Saludos Franco Dosil
https://www.manualslib.com/manual/510640/Sony-Mhc-Ec55.html
whoa...that was a quick response! I'll check..
That was it. I saw an antenna hooked up on the back already but did not realize there were 2 antennas. 2nd antenna had fallen behind the shelf and was not visible. Thanks! I got my AM back...now can you get the baseball season to start sooner? :)
I have the Sony mhc gx250 just purchased used any idea why the tuner not working everything else works fine but no sound when tuner is turned on have both antennas plugged in no sound CD and tape boom any ideas
