Samsung HCL5515W 55" Rear Projection Television Logo
Posted on Oct 26, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Red and blue con - Samsung HCL5515W 55" Rear Projection Television
Anonymous
Level 3:
Top Expert:
  • Samsung Master 14,553 Answers
  • Posted on Oct 26, 2012
Anonymous
Samsung Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2716258
Points
48227
Adjustment or IC replacement---the adjustment with the original remote via the customer menu should be tried first----set if has convergence should use either two stk-392-040 or -020 chips that are interchangeable with the -040 being the higher current part and more expensive.
Lg 42" tv not displaying screen image
The t-con board controls the picture. To test it shine a flash light on the screen abd see if you can see an image when the TV is on. If you do then the T-con board is OK. Look at the back light ballast board (sometimes is part of the power supply board) If you see no movement or a dim picture with the flash light, then the T-con board is gone. You can get parts here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Color is not right. Things suppose to be blue are green and peoples skin is red
HI,
Probably the t con board is faulty. if its 32 inch tv then you would be luck if you find a septate t con board rather than one which is integrated to lcd panel. . if its 40 inch or above you will surly find a separate t con board .
check the video too
HOW TO REPAIR SAMSUNG TV WITH BAD PICTURE como reparar samsung tv...
www.electro-medical.blogspot.com
How to regas a goldair air con unit
ok first the blue hose onto the suction line(the thicker of the two pipes)of the ac unit,the yellow onto the vacuum pump.the red hose not necessary.After vacuum is completed remove yellow hose from pump and put it on gas bottle now you ready to charge the unit
How to hook up without connectors
car colors
yellow 12v switched
orange 12v con
green rf-
lite green rf+
grey lf- paired with tan
tan lf+
blue rr+
lite blue rr-
yellow lr- Paired with brown
brown lr+
pink pwr antenna
brown alone illumination
grey alone illumination dimmer
black ground
radio wires
purples rr
green lr
grey rf
white lf
red switched
yellow 12 con
bluewhite stripe ..amp turn on
blue power ant
black ground
hope it helps
100 s of red blue purple lines on samsung lcd tv
More than likely the T-con board has failed.If it's available seperately it's worth repair.If not you will have to replace the entire panel w/t-con board.Very expensive for the panel.
4helpful
Red blue green lines down my lcd tv screen
HP-R4252 NOT LCD TV
IF LCD TV has vertical lines try cleaning T-con board to lcd panel cable or replaced t-con board
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
