SOURCE: Convert internal hard drive to external back-up drive
Greetings
use the cd installer that comes with "Master Cooler"
after successful installation, u can now use the Hard drive.
SOURCE: EXT HD UNRECOGNIZED BY LAPTOP
Which operating system are you using? Windows XP or Vista?
Here is the website that you can download the driver for your external harddrive.
http://support.wdc.com/product/download.asp?modelno=WD1600JB-00FUA0+WD+&x=1&y=11
SOURCE: HD not recognized and makes 3 times beep...beep noise when conect
Sounds like the drive has gone south.
This is a bit of work, but if you have access to a Linux disc, load the Live CD and see if you can mount the drive from there.
This is not quick a quick solution but may be far cheaper than sending off to a recovery expert.
If you are not familiar with Linux, go to www.ubuntu.com and download the latest distro, V9.04. Download, burn a copy and boot from it. Be prepared to spend time doing this, but it may just save your valuable data.
I have many times been able to salvage data just by doing this, if Ubuntu sees the drive, you could copy the data to your C drive and reboot.
Best of luck!
tom
SOURCE: Folder on External Hard Drive showing up as empty and Access Den
you got corrup because of not properly ejecting of hdd.. okay.. try to connect again then rigth click the hdd then properties, tools, click the check now.. select all.. dont intirup it until done.. if desconnect the hdd will be damage at all..
SOURCE: wd portable hd - device attached to this system is malfunctioned
It could be that the Hard Drive inside the enclosure still works, not sure if you care about voiding any warranty as opening it up will likely do, but there is a very slight chance that the Hard Drive itself will let you get the data off it. I am not sure what the connector to the drive is on the inside though as I have not taken one apart myself, :).
Testimonial: "Thanks a million. I think I will take it to a data restore specialist to see if it can be recovered. Thanks again!!"
I was using with Win XP SP3 and also Win7 Pro, It would recognize the disk in Disk management but not in explorer until I assigned a Drive Letter to it and keeps asking me to format the disk.
I am running Easy Drive Data Recovery scan on it now it's at 19% and has already found almost 8000 files, I am still optimistic I can find a way to recover this data.
