Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
John Callaghan Posted on Sep 30, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Reboot just as op sys starts -never gets into it
Tried to start system from a couple of Linux cd's. Will get to boot options point, (eg, try it, install, etc), Then when asked, starts the boot but reboots, never getting to the op sys. CD drive and discs OK, PSU Ok, (there is no HDD -I'm using Puppy linux to see if I can get it to go and that does not need a hdd). I am wondering about ram?
tech you
Level 3:
Master:
  • Master 439 Answers
  • Posted on Oct 04, 2017
tech you
Master
Level 3:
Master:
Answers
439
Questions
Helped
67433
Points
1177
Hi this is selena am expert to help you to fix this issue for you,kindly call me on +1(518)348-9393 and we will be glad to help you.
4 Related Answers
Anonymous
  • 37 Answers
  • Posted on Feb 17, 2009
SOURCE: enabled the boot options in boot manu but unable to boot the linu
IT DOSENT MATTER WHICH O/S U R USING. THE CD MUST BE BOOTED FROM THE CD DRIVE. JUST CHECK YOUR CD DRIVER. IT MUST BE NOT WORKING PROPERLY.
PERIODICALLY EVERY CD DRIVERS NEEDS SERVICE, LIKE LANCE CLEANUP AND BELT SETTINGS.
JUST SERVICE YOUR CD DRIVER OR CHANGE IT WITH A NEW ONE.
NICE DAY.
KETAN1190
Anonymous
  • 189 Answers
  • Posted on Mar 10, 2009
SOURCE: Recurring Reboot
1. Try to start it in Safe Mode and run antivirus and see if it can be fixed.
2. If it doesn't, I am afraid you may have to reinstall.
Thanks,
S
Anonymous
  • 808 Answers
  • Posted on Sep 08, 2010
SOURCE: Windows Vista BSOD
Confronting Blue Screen of Death popularly known as BSOD is one of the worst nightmares for any computer user. It can happen in all the Windows versions. Win 7 is no exception to it to BSOD. Luckily, there are ways to fix Win 7 Blue Screen of Death problem.
Usually with BSOD, one can not do any work on computer. Computer hangs, restarts or shut down on its own. There is always a great danger of losing unsaved work.
The situation demand urgent action on your part to continue safe and smooth computing.
I am sharing few tricks of the trade that will surely help you whenever you see tragic Blue Screen of Death in Win 7.
Anonymous
  • 1940 Answers
  • Posted on Mar 09, 2011
SOURCE: My HDD got infected with virus.I boot up my
In your BIOS, do you have the First Boot Device set for the CD-ROM drive? The message NTLDR is missing, press any key to restart, means your PC is trying to boot from the Hard Drive. Check your BIOS and configure the First Boot Device for the CD-ROM drive. Then try booting from the XP CD again. You may have to press a key to boot from disc, but you will be prompted to do so if necessary.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Samsung rc520 wont start blue screen
Your Graphics Adapter may be out? Have you tried to boot to Safe Mode or a System Restore/Recovery? Have you done ANY updates? Remove ALL media, CD,DVD,USB, unplug, remove battery, leave battery out, plug in, reboot, Try this Win 7 procedure: http://www.sevenforums.com/tutorials/666-advanced-boot-options.html The other option is to re load Windows.
I'm trying to load windows 7 on my hp pavillion dv6725 us laptop, it started installing then it failed i tried again it wont boot from cd but the rom is working th lights are blinking the tray is...
Do you have the correct version of Windows 7? You cannot load a 64 bit onto a 32 bit system, you cannot load Ultimate onto Home.
Do you still boot to the original op sys, what was it?
Sir my window 7 is currepted what can i dorahul
If your Windows 7 is corrupted you may have a couple of options. The most extreme, but fairly simple is to reinstall Windows. If data is not backed up, however, you may lose this. You will need your Windows 7 CD/DVD to reinstall Windows. Insert the disc into your Computer, reboot the computer and go into your BIOS. Set the computer to boot from the CD/DVD drive first. Once your computer reboots it should boot into the CD and start the install process. You may have a recovery option here.
Another option is to use System Restore which is a built in Windows Utility. To use System Restore go to Start > Programs > Accessories or Administrative Tools and choose System Restore. Alternatively, you can go to Start and in the search box type System Restore. Select a Restore point before your system was corrupted and see if this resolves your issue.
If you can't boot into Windows then you will need to boot into Safe mode to work on the problem. While the computer is rebooting keep pressing F8 and you will get a menu. Choose Safe Mode at this menu and then perform your troubleshooting.
Regards,
G33k
1helpful
3answers
My laptop is slow and wont reboot
Put the Windows Op Sys CD in the drive and boot the system, Interrupt the boot process and go to the BIOS. Select the first boot up device to be the CD/DVD drive and then save the settings. Exit from BIOS and reboot the laptop. Windows should start from the CD. You will see an option to repair etc. Select the R Repair option and follow instructions. Once this has completed, and it may take some time depending on how full the HD is go to www.ashampoo.de and download the 30 day free trial application of Ashampoo and run this over your system to clean it up. Then run the defrag option in the MODULES tab - Optimise Performance Option- Defrag 3. Once completed your system will be cleaned and optimised. In order to make the performance even better - add additional RAM to the unit - you can never have too much and make sure that the HD has a minimum of 10% space remaining otherwise the laptop will slow down in operation.
1helpful
3answers
Error messages :system32\hal.dll missing or corrupt"
Looks like you might have to format your drive and reload windows from scratch,unless you can restore deleted files from your recycle bin
1helpful
Pc linux OS 2007 stuck after seconds
One Idea is You might have some Ram issues If you can try and boot up again and run the MEMTEST option and see what happens
I want to boot from cd to change windows from xp to 98
enter the bios set up on start up. Go to boot sequence, change 1st option to cdrom instead of main drive. Save and exit. Let it boot up, put 98 disk in cdrom. Shut down, reboot and win 98 installation will begin asking you to over write existing ops sys. Choose yes and the install should be a breeze after this. Once xp is installed, dont forget to return to the bios and change back your boot sequence to hard drive as primary /master.
New operating system wanted
after formating hdd u can install any op sys on ur computer, please put ur op sys cd in drive
after starting computer and boot it with this cd when u start ur computer u will get a massage "press any key to boot from cd"
and install xp from cd also format ur hdd with xp op sys
it will solve ur problum
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
