The product has been working fine for more than a year, recently it stopped working. I have enough rice and water on the recipient, and also the electric outlet has been tested ok with another appliance. I press down the switch but the COOK light does not turn on. I unscrewed and removed the bottom plate and tested the mechanical system and seems to work properly making contacts as (I think) expected. SO I think there is something wrong with the electrical parts. I'd appreciate any suggestions on how to test, check, remove the electrical components. thanks
SOURCE: rival rice cooker stopped working
Mine just did as well today. Thought I blew a fuse, but no, just not working, although it did finish the pot of rice.
SOURCE: Rice cooker stopped working
Sounds like the Thermal Fuse inside is blown unscrew the 2 screws on bottom of the cooker you should see a small 2.5 inch insulation wrapped wire leaving a ceramic mounting block to one of the element poles. Now you take off the nut and unscrew it from the pole. Cut off the insulation and underneath will be a Thermal Fuse. If you have a Ohm Meter or a continuity tester attach each lead to either side and it probably will test negative. Part # is written on the Thermal Fuse. Probably a
SEFUSE
SF188E
192C
10A
250V
They are for sale on ebay for $9.99
I'm trying to get mine cheaper elsewhere
SOURCE: rice burning on the bottom
i found out if you drizzle some olive oil in the bottom before you add your rice and water or broth this helps alot just a nice color no burning good luck angia in florida
