Several problems with this printer, 1st is the printer keeps telling me there is a paper jam, there is nothing in the printer jamming anything, as soon as i open and closer the ab door the warning light gos out and the printer will print 1 page then the light comes on again. 2nd problem i have changed all the toners but the printer is still printing very feint, is there a cleaning programm for this printer ?
SOURCE: K toner cart out, Epsom C1900 Aculaser color printer
i had the same problem as you i feel very upset with epson that they did not help you for me what i had to do is lay my printer on its side with the door to the toner facing you taking the toner out looking down into the bottom you will see a little plastic block wist it half way till it stops then reinsert the toner becarefull not to drop it in that shoud be fully fitted inside then put the unit back the right side up and start the printer up this shpuld fix your problem ok thanks
SOURCE: Epson Stylus CX8400 Paper Jam Error
I have the same exact problem of paper half torn removed but I can not see the other half anywhere. The printer has hardly worked for at the most six pages and now showing paper jam error. How do I fix it?
SOURCE: CX3810 printer will not print
Take out the cartridges from the printer, put them back.
Remove the printer completely from your computer. Reboot. Re-install the printer.
Try to print again.
It sounds like your print heads are shot.
SOURCE: Epson Aculaser C900 - Paper Jam Notice, but no Jam?
Step1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step
Turn off the printer.
Step
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step
5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step
8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step
9
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
SOURCE: printer keeps saying paper jam
we had the same problem at the college where i work. the print queue had somehow clogged up to such a point where the printer was doing this. the constant paper jam light & the printer taking paper when printing test sheets etc. we solved it by deleting the printer & then re-installing the drivers. may not work for everyone, but it certainly worked for us.
Clean your roller and see if there are loose gears or trapped objects inside. As for the faint prints, check your toner density. The normal setting should be 3. See basic troubleshooting
