Olympus DS-3500 ODMS Pro Digital Voice Recorder Dictation Machines Logo
Logan Posted on Oct 24, 2012
Pro-digital voice recorder sound
Running windows 7 and using the Olympus Dictation Management System CD than came with the product. i can get sounds through the headphones using the windows check, and all indication bars on the ODMS transcription module show something is playing/happening, but i cannot get sound to come through the headphones for transcribing.
davo990
Level 1:
New Friend:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Nov 12, 2012
davo990
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
8
Questions
0
Helped
3218
Points
8
For all information about dictation and transcription please visit www.dictaphones.com, alternatively simply ring Speak-IT on (0121) 456800. Their team of specialised staff with over 30 years of experience in both dictation and transcription will be more than happy to assist!
User manual philips voice tracer DVT4100
[PDF]User manual - Philips
https://www.dictation.philips.com/index.php?...
Philips1 Important safety information. 5. 1.1 Safety instructions. 5. 2 About this user manual. 7. 2.1 Symbols used. 7. 3 Digital Voice Tracer. 8. 3.1 Product highlights. 8.
Voice Tracer digital recorder, DVT1700 - Overview - Philips
https://www.dictation.philips.com/.../voice_tracer_digital_recorder...
PhilipsVoice Tracer digital recorder. Speech to text. DVT1700 ... Manuals and documentation. Quick start guide (1.3 MB); User manual (867 KB); Leaflet (563 KB).
Philips1 Important safety information. 5. 1.1 Safety instructions. 5. 2 About this user manual. 7. 2.2 Symbols used. 7. 3 Digital Voice Tracer. 8. 3.1 Product highlights. 8.
Error message Olympus DM420: Can't make the system file. Connect to PC and delete unnecessary file.
https://www.yumpu.com/en/document/read/49760600/olympus-dm-520-dm-420-digital-portable-voice-recorder-dictation-
DSS player won't download to PC
I know you will need the serial # to install, if you don't have one you can get this software version it say that it is for the Olympus DS-5000 digital recorder but also it is compatible with the previous version Olympus DS-4000 digital recorder at http://www.tvps.com/Products/Olympus-AS-5001-DSS-Player-Pro-Dictation-Version-5---New__OL-AS-5001.aspx
1helpful
How do I make a audio CD from my dictation machine
If you are already using your dictation machine then you don't need to install its software as its already installed. Now you only require Nero for burning files to CDs. You also require a CD writer installed on your pc. You shall know where your files are saved when you record through dictation machine. If you can't find the recorded files kindly comment back.
My ds3000 dictation machine wont work with vista
The DS-3000 and the software is was shipped will not operate with Windows Vista. The software i suspect you have will DSS Player Pro Release 2 or 3. If you obtain a copy of DSS Player Pro Release 4 you will be able to use the DS-3000 on Windows Vista 32 bit or 64 bit without problem.
2answers
Olympus AS-2300
The new DS-5000 SW has still got some quirks. The RS-25 is no longer available and I too have had issues with the 27. If your PC has a serial port try the serial plug, I know it is a step backwards but it has worked for me several times. Hope this helps. For now I steer clear of the DS-5000's.
Editing? Can dictation be paused, then go back part way and....
you can not do this with the Olympus ws-100, you need a dictation machine that has the editing function which allows you to easily insert, overwrite, partially erase files and continue on the same file, most of the digital dictation units have NEW FILE BUTTON , you will stay recording on the same file till you press new.
Look at Olympus DS-2300. Olympus DS-33300 or ds-4000.
Very bad recording
Be sure you are in the SP record mode and use the dictate conferance setting depending on your environment.
Top Olympus Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Olympus Office Equipment and Supply Expert? Answer questions, earn points and help others
