I have a MSI model MS-7151-010, in which I can't figure out how to put the wires...I.E....HDD LED, POWER, etc.
Http://www.msicomputer.com/product/p_search.asp.Go to msi for a mother board manual or wiring diagram?see support.richardm69
Hi bossman9628A, normally its the wire colors that messes everyone up when trying to connect the front case wires to the motherboard. The MSI RX480 Neo2-F, AKA MS-7151 MB is no different but does use a second set of pins just to help you get more confused.
Gather up all your case wires. You'll notice there is one color that is common. Chances are that color is white & is being used for the ground wire. Other colors like blue, green, red, light blue, light green & light red ECT are used for positive. The speaker uses black for ground/negative.
So looking at JFP1 at pin 1 is positive +. Pin 3, which is to the right of pin 1 is negative -.
The manual does show you which pin is negative & which is positive. Pin 1 = (HD_LED_P). The _P stands for positive.
Pin 3 = (HD_LED_N). The _N stands for negative. Do not connect the Power led at JFP2. Keep the power led connected at JFP1.
Do connect the case speaker at JFP2. Most cases do use 2-pin connectors but others use 3 & 4 pin connectors. If your case is such you can remove a wire from a connector by using a decent needle. There is a small black tab that you can pull towards your self while pulling the wire out. You can than slide the wire back into the connector where you need it. You'll know the wire is inserted correctly because you'll hear or feel it snap into the connector. If by sme chance you get a led backwards, don't freak out. The leds use 5v DC. Just shut down the system & turn that led 180deg & reconnect it.
Good luck bossman9628A!
More questions?
Mike
please vote....
Need the manual or drivers? Go to this link:
http://global.msi.com.tw/index.php?func=...
Mike
SOURCE: HOOKING UP THE WIRING PROPERLY
http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=167
Download the manual, it will show you the exact wiring information you need.
