Whirlpool Gold Freestanding Ice mkr - sm amounts of thin ice
I think it is a model GI15NDXTB or a predecessor. It is getting plenty of water and I've run the cleaning cycle with appropriate cleaning fluid diluted according to instructions 3 times.
Well this thing is made to make ice cubes so if the ice cube are to small thin then you water supply must be restricted because its cold enough to make the ice just the volume of water isn't their .Check the feed system for restrictions .
You need to remove the ice maker and open the front carefully. It has small micro switches inside it and it sounds like one that opens the water control valve is stuck in the on position. Be careful not to loose the arm spring and how that goes back together as you take it apart. Sea Breeze
your hollow cubes tells me your ice-mkr is not receiving enough water. first check water supply. does your refrig. have a water filter? also you could have a bad/restricted water valve.
i'll try to help w/out a model number but here it goes. more then likely your ice-mkr has stopped.right? if so turn ice-mkr off and it should help w/your freezing problem in the freshfood side.now find out why your ice-mkr is not making ice. things to look for are
1.no water hook up or water turned off under the kitchen sink.
2. a cube stuck in the ice-mkr's ejecting teeth.
3. a defective ice-mkr. vist www.searspartsdirect.com and input your model #,then choose ice-mkr to buy it. good luck
Freezer too cold and not much water. When it is empty of ice check the water level in the ice tray. Probably not even halfway up. Unplug fridge for 8 hours and plug it back in. Need more help please live chat. If this has helped, please rate as fixya.
You said, The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
How old is the fridge? When have you last changed the water filter. Should be down below at the front grille! Try these tasks!
If the ice maker is not producing ice or not enough ice Refrigerator connected to a water supply and the supply shutoff valve turned on? Connect refrigerator to water supply and turn water shutoff valve fully open. • Kink in the water source line? A kink in the line can reduce water flow. Straighten the water source line. • Ice maker turned on? Make sure wire shutoff arm or switch (depending on model) is in the ON position. • New installation? Wait 24 hours after ice maker installation for ice production to begin. Wait 72 hours for full ice production. • Freezer door closed completely? Firmly close the freezer compartment door. If the freezer compartment door will not close all the way, see "The doors will not close completely." • Large amount of ice recently removed? Allow 24 hours for ice maker to produce more ice. • Ice cube jammed in the ice maker ejector arm? Remove ice from the ejector arm with a plastic utensil. • Water filter installed on the refrigerator? Remove filter and operate ice maker. If ice volume improves, then the filter may be clogged or incorrectly installed. Replace filter or reinstall it correctly. • Reverse osmosis water filtration system connected to your cold water supply? This can decrease water pressure.
Let me know how it goes! Huuum Please remember to leave a rating!
