If you have a step by step on how to loosen the housing that holds the Turn signal switch please post. I can't see having to buy the whole manual to just replace a module.If you have a step by step on how to loosen the housing that holds the Turn signal switch please post. I can't see having to buy the whole manual to just replace a module.
Video would be great but 1,2,3, instructions should be fine. Manuals cost sometimes more that the part, labor and with todays economy everything is so expensive, that's why are replacing things instead of having other do it for them. I do want to thank Thomas for the part needed.Video would be great but 1,2,3, instructions should be fine. Manuals cost sometimes more that the part, labor and with todays economy everything is so expensive, that's why are replacing things instead of having other do it for them. I do want to thank Thomas for the part needed.
Hey Tony,here's a guide on how to replace,if this is not right,let me know and Iwill my best to make it righthttp://www.autozone.com/autozone/repairi...Hey Tony,here's a guide on how to replace,if this is not right,let me know and Iwill my best to make it right.http://www.autozone.com/autozone/repairinfo/repairguide/repairGuideContent.jsp;jsessionid=8D70318B2A024F235C77AA36C2399A0E.diyprod4-b2c7?pageId=0900c1528003bf03
Does anyone know how to replace the actual unit? The free manuals were dead end. I need how to take it out and replace.Does anyone know how to replace the actual unit? The free manuals were dead end. I need how to take it out and replace.
You can't post conmments that contain an email address.
JustAnswerhttps://www.justanswer.com > Saturn Repair
Sep 21, 2012 - Hello I will help you with your question,. The fluid procedure for the 6 speed is shown below, look this over and let me know how I can help ... 1 answer · Top answer: Glad to help and please let me know if you have further questions Thank you
locate the crankshaft sensor, disconnect electrical plug, make sure around sensor is clean so grit etc doesn't fall in when sensor is out, unscrew with appropriate spanner, replace with the new sensor and reconnect plug. may also need some thread tape on thread before screwing in.
Your not going to like this but the head lamp will have to be removed to replace the bulb. There will be three screws/bolts to remove then lift up ward and pull gentle out and disconnect the headlamp wiring replace bulbs do not touch the clear lens after installing bulbs set headlamp back in and refasten light see diagram below for fastening points
To replace just the fascia (soft painted part) around $500. If there is more damage, the cost will go up quickly. You may get lucky and find one the right color at an auto recycler (junk yard) for around $150 plus installation.
