Need a driver to run with Windows 7.
SOURCE: Hp deskjet 1280 driver printer for windows 7
download hp deskjet 1280 for win 7 32 bit http://www.wupload.com/file/3797628/HPDJ1280_for_win_7.exe
SOURCE: HP DesignJet 450c driver for windows vista
THIS SOLUTION IM ABOUT TO TELL YOU IS IN MY EXPERIENCE THE EASIEST ONE JUST DOWNLOAD THE WINDOWS XP DRIVER FOR THE HP DESIGNJET 450C PRINTER AND INSTALL IT INTO THE WINDOWS PRINTER PLATTFORM, YOU MAY SEE SOME ANOUNCEMENTS FROM YOUR COMPUTER TELLING YOU THAT THE PROGRAM YOUR TRYING TO INSTALL MAY NOT BE COMPATIBLE "DONT LISTEN TO THEM" JUST CONTINUE YOUR INSTALLATION AND PRESTO YOUR DESIGNJET PRINTER WILL WORK PERFECTLY
SOURCE: Windows 7 AutoCAD 2010 HP DeskJet
Install the Driver Using Windows Update with a USB Connection (Downloadable Driver Not Available)
As suggest by HP, try this,
HP All-in-One Printers - Installing the Product with the USB Cable and Using the Windows Update Driver or the Driver Located in the Windows 7 Operating System.
Hope it helps.
SOURCE: Need updated driver for HP CP2025dn printer
If it's available it will be at www.partsurfer.hp.com under support and downloads. These are free.
SOURCE: Will HP Deskjet 722c work with Windows 7? There
If you are using a 32
bit version of Windows 7 you can add a driver using the following: go
to the Devices and Printers folder, Add a printer, Local printer,
LPT1: (or which ever parallel port the printer is connected to),
select the Deskjet 720c driver. You may need to click on the Windows
Update button if the driver does not show up initially in the list.
If you are using a 64 bit version of Windows 7 there is not a solution at this point, the supplied drivers have an issue.
you can download driver athttp://h30413.www3.hp.com/SupportServices/country/us/en/support/1055CM.html.htmi hope this will help youthank you
