Question about Intermatic Malibu 300W Power Pack Transformer ML300RTW
Transformer is Humming loudly, how do I stop - Intermatic Malibu 300W Power Pack Transformer ML300RTW
  • Intermatic Master
  • 5,390 Answers
Copy following link for general troubleshoot and tips, and warranty information, and trippers.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
ML300 series transformers make sound.
Some make more sound thAn others.
Used styrafoam to separate transformer from contact with building so sound is not carried.
These transformers have 10 year limited warranty.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Oct 24, 2012
6ya staff
SOURCE:
How do I stop constant loud humming and buzing sound from transformer
Transformers make noise..
If transformer is buzzing, then it has probably gone bad.
Gene
Water Heater Timers Save Money
Dec 11, 2014 | Electrical Supplies
Loud huming from my 300v low voltage lighting transformer
Transformers make humming sound.
Oct 23, 2012 | Malibu ML300RTW - Low Voltage Power Pack...
My JES636WK01 microwave heats up but it makes a loud humming noise. I suspected the Magnetron and disconnected it. The microwave was then operated and the n oiuse was the same. Do you have any ideas
Disconnect the HV transformer leads from the magnetron and the capacitor. Make sure none of the wires are touching the chasis or other parts. If the loud humming sound is still present, it is the High Voltage transformer making the noise. If the noise goes away, it is the High Voltage Capacitor going bad.
*MAKE SURE TO UNPLUG UNIT BEFORE TOUCHING ANY OF THE HIGH VOLTAGE LEADS! ALSO, DISCHARGE THE CAPACITOR BY SHORTING THE TWO SIDES AGAINST EACH OTHER!
Apr 15, 2011 | General Electric Microwave Oven
Everthing works but the heat and it makes a loud humming noise.
The magnetron has shorted probably loading down the high voltage transformer where the humming is coming from. It is cheaper to replace the oven than have it repaired.
Jan 14, 2011 | Maytag UMV1152 Microwave Oven
Humming sound when on/off
humming sound when on is usual if the volume is turned up.
humming sound the same when on or off could be transformer plates fluxing.
if loud recommend replacement of power supply.
if ok then recommend unplugging the device after use.
Nov 13, 2009 | Velodyne DPS-10 Subwoofer
It is making a humming noise but not heating.
sounds like a crack in the magnetron
a bad transformer
or a bad rectifier
sorry i cant be more help
Oct 10, 2009 | Maytag MMV5100A Microwave Oven
Loud humming noise
Usually a humming noise is a transformer going bad.
Jan 06, 2009 | Samsung HCM4215W 42" Rear Projection...
Loud humming
If this is an electric resistance heater then there is no power supply or transformer. I had a baseboard heater that would hum loudly and I found there's a wire that runs along the bottom to connect the far end of the heat element to the electrical wiring at the supply end. This wire becomes magnetized from the current flowing through it and vibrates in the channel it runs through. I was able to open this channel and squirt a bit of silicone caulk in to keep the wire from vibrating and the hum is gone.
Dec 19, 2006 | Honeywell HZ514 Baseboard Heater
Intermatic Malibu 300W Power Pack Transformer ML300RTW Logo
485 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Mike
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
