Question about IBM Lenovo ThinkPad T410 Notebook PC
Lenovo thinkpad t410 screen upside down
My screen is inverted. Did not happen when I was running Windows but started when I installed centos 6.3. THough at first the screen was normal but started flipping after a few days. Now the screen is inverted from the moment it boots up. I have tried different install CDs including fedora -- same problem. Will resetting the bio fix this problem? Any other ideas?
  • 564 Answers
Press Ctrl Alt and up arrow
Posted on Oct 23, 2012
6ya staff
SOURCE:
myob247
Georgia B
  • 1342 Answers
SOURCE: IBM ThinkPad T20 - Won't boot windows
Click HERE for info on IBM passwords
Posted on May 24, 2008
Pyrhyc
Ryan Rogers
  • 2028 Answers
SOURCE: Stuck at IBM Thinkpad Splash Screen
Sound like a memory chip has failed. Try removing the memory, I believe these have on board, but not sure. If it doesn't have on board, you will need at least one chip in. If the problem is still there, try removing the CD drive, occasionally they can cause a no start. If it's not the memory or the CD drive, then try a bios flash. You will need to create a bootable disc from IBM's support site using a different machine (obviously).
If the bios flash doesn't fix it, them the problem will lie with the motherboard.
Posted on Jun 27, 2008
Pyrhyc
Ryan Rogers
  • 2028 Answers
SOURCE: IBM Think Pad T22 auto -shut down a few minutes
Try running it without the battery. Sometimes an IBM battery can develop a short and cause this. If it still does it without the battery, I'm afraid it's the power management chip on the motherboard, and the motherboard will need to be replaced.
Posted on Jul 11, 2008
Anonymous
  • 46 Answers
SOURCE: IBM thinkpad T23 2647 install help
Many lockups are caused by incorrect (wrong kind or too much) or faulty memory modules. If you are comfortable doing so, open the memory door on the bottom (most likely) of the PC after first unplugging the PC and removing the main battery. Verify, if you can, that the memory is correct for PC. If the modules don't specifically say what type and speed they are, do a search on any numbers on labels. Go to www.crucial.com and use the memory finder on the left side of the page. If the memory you have is the correct type, try the following: If there are two modules, remove one, then try your XP install again. If it crashes, reinstall the removed module, and remove the other one. If either XP install works, the removed module is faulty. Replace it. If it still crashes, try to borrow some proper memory from someone. If all of this still doesn't work, it could be the hard drive and NOT the memory. In this case, about the only thing you can do is borrow a copy of a bootable CD-ROM based program that can check your hard drive. Many hard drive manufacturers have something like this.
Posted on Mar 04, 2009
Anonymous
  • 1383 Answers
SOURCE: forget BIOS Password (Laptop - IBM Thinkpad Lenovo R60)
For that you need to reset factory defaults settings for bios.
For reset bios u have to open back side of your laptop then u find motherbord circuit there.
pull cmos cell on motherbord for 15 minute then it reset to defaults.
Also u can reset with jumper settigns read carefully on mother bord there is 1 jumper near cmos cell u read there " bios reset or clear"
It is on 1-2 position right now set it in 2-3 position then power up then all bios settings are reset.
then again set it in 1-2 its original position.
Posted on Jul 29, 2009
Is the power cord for Thinkpad T410 and T420 interchangeable
Yes there are two types one is a 65 watt adapter and the other is the 95 watt.
Some units may need the higher wattage due to hardware specs. But they will all run on both.
http://support.lenovo.com/en_CA/product-and-parts/detail.page?&LegacyDocID=MIGR-62473
http://support.lenovo.com/en_CA/product-and-parts/detail.page?&LegacyDocID=MIGR-61193
Feb 06, 2014 | Lenovo ThinkPad T410 Notebook
Thinkpad hungup on shutting down
Pull the AC plug, remove battery. You may want to do a System clean-up. I assume you have Windows 7? Use two freeware programs to assist you. 1, CCLEANER: http://www.filehippo.com/download_ccleaner/ This freeware program will clean the junk from your machine, in the TOOLS section, select STARTUP, disable ALL unnecessary startup programs, this will speedup starts, shutdowns and running. 2, MALWAREBYTES: http://www.filehippo.com/download_malwarebytes_anti_malware/ In the install UNCHECK the TRIAL PRO version, you want the freeware version, run a FULL scan, delete ALL results, reboot. Here are more tips to speedup Windows 7: http://www.techrepublic.com/blog/10things/10-ways-to-speed-up-windows-7/3332
Apr 04, 2013 | Lenovo ThinkPad T410 Notebook
Screen inverted t410
How is your screen inverted? Color wise? Upsidedown?
  1. Right click on the Desktop and select "Properties." Click the "Settings" tab and then select "Advanced."
  2. Click the "Driver" tab and then "Graphics Properties."
  3. Press "Display Settings" and uncheck the "Enable rotation" option. Click "Apply" and then "OK."
Oct 23, 2012 | IBM Lenovo ThinkPad T410 Notebook PC
I can reset my password lenovo t410 pls try to help me
Try F8 or the F that you see in the screen at start up to to enter in BIOS setup.
Sep 18, 2012 | Lenovo ThinkPad T410 Notebook
Cannot use the keyboard even the Ctrl+Alt+Del On the Levono T410
You might have some viruses and malware.
Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below.
Download, Install and Run Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
When Installing choose the non-pro version.
Download, Unzip, Install and Run TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Download, Install and Run Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
If you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Make sure to select ALL of the "threat categories" when you install or configure Avira...
You should be in pretty good shape if you run and install all of these programs.
Jul 22, 2012 | Lenovo Ibm Levono Thinkpad T410 Core I5...
Lenovo T410 model "The Display Driver
Try uninstalling and reinstalling the drivers again, maybe that will fix the problem. Also please rate me have a great day. :-)
May 10, 2011 | Computers & Internet
Fn F8 is not working with Lenovo T410 . How do I turn this off ?
Had same problem. Download the new Trackpoint driver from lennovo the file name for 64 bit machine Windows 7 install is
6hgy31ww.exe
Once installed (you will have to reboot too), you will be able to go to Mouse properties, and click on or off the UltraNav functions you don't like. STP
Nov 05, 2010 | Lenovo ThinkPad T410 Notebook
IBM Lenovo ThinkPad T410 Notebook PC Logo
601 people viewed this question
Top IBM Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
