The screen first had lines running thought it and you can't read the words and know it goes totally blank. How do i find what the part I need to buy to fix this problem?
SOURCE: sharp carousel r-1481
Ceramic fuses of 15A or 20A rating are available at home improvement stores like Lowe's, places like Wal-Mart and local appliance stores.
Ceramic fuses are preferred because they are considered flameproof.
SOURCE: Sharp Carousel Microwave door latch stopped working door won't stay closed
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have *critical* safety & disassembly info at our site, linked here: http://tinyurl.com/yzjozk
We also have this full service manual at our site: http://www.microwavedisplay.com/R1480_R1481_R1482_sm.pdf
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: R-4H84 Sharp Carousel II microwave oven stoped working
A microwave can be dead for many reasons.
The fuse is normally located on the floor of the chassis behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
SOURCE: sharp carousel microwave doesn't spin
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If
yours is not set to be off via the control panel, and it won't rotate
or it sounds like it's grinding, etc., you may have a bad motor or
plastic coupler.
To
replace either, you need to unplug power, then remove the bottom cover
of the oven. In some brands, you have to cut the motor cover off with snips, then use a
screw when reassembling it.
The best place to order Sharp parts is Tritronics. You can also call them at 866-779-5835
SOURCE: Sharp Carousel Microwave R-1505
There are two options for this model:
1.
You can order our exclusive modified control unit (part # CU150) with our proprietary upgrades
for $95, or add $15 for a new select button assembly making it part # CU150B for a total of $110.
Then if you return your defective control unit in repairable,
good cosmetic condition, we'll give you a core refund of $30.
It comes with a one-year guarantee. For
details, see: http://www.microwavedisplay.com/exchange.htm
2. We can repair your existing control unit for $39.95 in about a week or so with a one year guarantee.
Feel free to contact me directly (and please remind me of your
model number) for more information & help.
We're
William E. Miller, AS-EET
[email protected]
