There is an eror code 20 that keeps turning on and it wont spin
Hello - The error code "E20" typically means the water is not draining properly or not pumping out fast enough. Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
SOURCE: Frigidaire Affinity front load washer will not spin
sounds like the impeller on the drain pump is blocked. Noise could be coins trapped in drum. Check filter thoroughly, if you cannot remove blockage you may have to remove tubes from pump to clear out any blockage.
SOURCE: my frigidaire affinity wont start
Yes, the original issue was the control from the beginning. the control is damaged and it cannot register the latch at this point. this is necessary and , it will fix the issue.
SOURCE: Frigidaire Affinity dryer error code?
HELLO,
I HAVE A FRIGIDAIRE AFFINITY DRYER (AEQ6000CE32). WHENEVER I PUT THE CLOTHES IN IT JUST SPINS FOR 10 TO 15 MINUTES AND SHUTS OFF BEFORE THE ALLOTTED TIME. THERE IS NO HEAT IN THE DRYER. ANY SLOUTIONS?
SOURCE: Frigidaire affinity front load. Starts
Welcome to FixYa.
Based on what you've described,...you likely need a door lock/switch assembly.
The door latch is likely the single most common fault (which prevent's any spin, and consequently drenching wet clothing at the end of the cycle) with the frigidaire/electrolux built washer's, aside from pump's being obstructed.
I think it fool's many people because the lock indicates it is energized on the panel, however the built in "monitor" switch inside the assembly fail's. I do see a lot of these particular machine's...unfortunately.
You should be able to purchase one at most local brick & mortar stores or on-line part's depot's such as "searspartsdirect.com" "repairclininc.com" to name a couple. They usually sell for about $50 or so, part # 1531974 ( # at repairclinic.com ) and are relatively easy to replace. It should resemble the image here...
As for replacing said switch, There are a couple ways to access it, through the top and squeezing your arm down the front or the way I prefer, remove the front bellows spring/retainer.
1) **unplug the washer from the wall...safety first of course.**
2) Remove the spring, get it started where the spring is located with a small screwdriver. Once you`ve got the spring/retainer off ( it comes off and on pretty easy by hand ) pull the gasket/bellows back away from the cabinet.
3) Undo the two screws holding the switch to the cabinet, pull the switch out ( there is just enough slack in the wires so don`t pull too hard ) and swap the wires from the old assembly to the new one and you`re in business.
4) To put it back together, just reverse the removal procedure. The trickiest part is the retainer. Rap the retainer around the boot leaving the spring for the last...and make sure the spring is located at the 6 o`clock position...usually. Just wherever it was initially.
Let me know if you need further assistance going forward or if my instructions are not clear.
P.S.
There is a slim chance of a faulty motor or motor control board, but that would not be where I would direct you to start...those are exceptions rather than the rule.
Thank you for visiting FixYa today. Good luck.
Regards,
Macmarkus :)
