It sounds like the feeddogs are in the down position, look at the
area where the needle plate is and see if you can see the feeddogs?
you can even run your finger over that area and you should be able
to feel the teeth. if you can feel the teeth or see them, then check
the feed dog lever to see if it's in the up postion.
the feed dog control lever should be in close to the bobbin area,
the question is under the necchi 4575 catagory, so that's the
information I'm putting in for the machine, if the lever is up then it's
possible that something is wrong with the lever or the feed dogs
them selves and they need to be checked at a sewing machine
shop
