Im playing VHS tape through my Canopus ADVC-110 but i only get it in black and white. This is an NTSC tape.
SOURCE: vhs pal video not working
Change the DIP switch to PAL, unplug the unit (no power), then plug it back in. You need to power-cycle the unit to after changing DIP switch settings.
Also make sure that your capture application is set to PAL mode, if there is a NTSC/PAL setting.
SOURCE: Can the Canopus ADVC-110 be reset
May i suggest that if the Canopus is stuck and both lights are on it may well be faulty but try this first.
slowly insert the fire wire into the back of the Canopus slowly does it when one light comes on stop inserting the fire wire and press input select till the lighth moves to the other side in my experiance digital to anolog,this may take a fiew goes and seem primative but it has worked for me and then eventialy the canopus corrects its self if this has been helpful please put a pound in the charity box of your choice and email [email protected] just to let me know good luck bye.
SOURCE: Where can I download a User Manual for Canopus ADVC-110
The following is a link to the manual (http://canopus.vo.llnwd.net/o2/unsecure/DL/ADVC110/documentation/ADVC110-e.pdf)
SOURCE: My Canopus ADVC-110 has both input light on and I
The problem got no free response so I ordered a new unit.
SOURCE: I need an Canopus ADVC-500 Service Manual.
Create an account at http://www.grassvalley.com/login?r=/ (company making Canopus ADVC-500).
Register your product (need serial number).
Then you can click on: View Registered Products > Desktop/Professional Product Downloads > ADVC500 > ADVC500 User Manual .
