Question about Kenmore 95592 / 95594 / 95595 / 95599 Electric Kitchen Range
My Kenmore Electric cook stove top has a black burn type spot on it and I can not clean it off. I have used baking soda, but it will not clean it. Any suggestions so I can get my stove top to look brand new again? It is not very old.
I poured a little amonia and used a heavy duty scrub brush to take off some of the same types of spots from a boil over. It took a little bit of elbow grease but it ewas the only thing that took it off after trying 6 or 7 different things. I hope this helps
Posted on Feb 11, 2009
6ya staff
SOURCE:
Kenmore glass cooktop discoloured
I use a straight edged razor blade on mine and it finally got clean
Nov 15, 2012 | Kenmore Frigidaire Glass Cook Top...
How do I clean my new electric Jenn-air cooktop with its glass top? Do I need a special cleaner for the glass?
  • Step 1 Wipe up spills as soon as they happen with a clean dry towel. According to the Jenn-Air website, for glass top cooking surfaces, you should do this even if it is hot since it will be harder to clean up later. Be careful not to get burned.
  • Step 2 Use a cooktop cleaner once it is cool. You can also use dishwashing detergent and water or just a baking soda paste (made with water).
  • Step 3 Apply the cleaner to a sponge, cloth or paper towel. For more stubborn stains, you can use a non-abrasive or "scratchless" pad.
  • Step 4 Rub the soiled areas until clean. Rinse well, especially if you used the baking soda paste as that can leave a residue.
  • Step 5 Use a razor blade for burned on and crusty stains that will not come off using the previous methods. Jenn-Air states to hold it at a 30-degree angle to carefully remove the stain.
  • Or you can use this on the link below.
    http://www.amazon.com/Blue-Ribbon-88100-Cooktop-Cleaner/dp/B000HM5INA
    Good Luck and please rate 4 thumbs up for the free answer
    Jun 25, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
    Stains on black enanamel stove top
    use caustic soda power mixed with water and wallpater paste so its a thin jelly . apply with a brush and leave over night . rince with warm water on a clean cloth. use rubber gloves and glasses for protection
    500g caustic powder
    2 pints water
    add wallpaper paste powder little at a time till jelly like
    Feb 19, 2010 | Jenn-Air JGR8850 Gas Kitchen Range
    I have a glass top stove that tenants NEVER cleaned. The two front burners are black. I have tried CeramaBryte Whink Cooktop, Baking soda, Scotchbrite type scrubbing pads, razor blades, and mixing all of...
    If you have tried all of the above.... BEFORE you go to the acid attemp that I do not think is a good idea.... Go to the local auto parts store and buy some engine degreser. Then give that a try. It is amazing how when you encounter a mega mess stove / oven that it will do the job most of the time. You will just have to use soap and water to do the final cleaning.
    Feb 14, 2010 | GE Profile JTP18 Electric Single Oven
    Good morning; We have a new Jenn-Air black glass
    Any proprietary glass top cleaner should be suitable. Avoid using a wire based scouring pad but the Scotch type 'plastic/foam' cleaning pads are ok.
    Jan 04, 2010 | Jenn-Air Ovens
    Need directions to clean my tappan oven
    1. Add baking soda to a cool oven. Sprinkle a thick layer of baking soda onto the bottom of the oven. Make sure the oven is completely cool before you attempt to do this. 2. Spray the baking soda with water. Using a spray bottle, spray the baking soda down until it is damp, not saturated. The water and baking soda together will help break down the food particles. 3. Continue spraying baking soda as it dries out. Every few hours spray the baking soda down again to keep it moist. Continue this process over several hours, spraying water as the baking soda begins to dry out. 4. Scrape out the baking soda. Scrape the baking soda out of the oven. Food residue will be scraped out with the baking soda. 5. Rinse the bottom of the oven out thoroughly. Yes, you'll still have to rinse out the oven, but next time you cook your food won't have an added taste of oven cleaner.
    If I had the rest of your model number I may find what Tappan now Fridgedaire Electrolux reccomends, but this is the least toxic. Have a great day..
    Feb 08, 2009 | Tappan TEF242 Electric Kitchen Range
    Having trouble cleaning splatters off Ingis Glass Top Stove.
    Use DeBruce Polish- a true multi-surface cleaner. There is a transfer of particulates from pan to glass surface aided by the heat. The cleaner will remove this "staining". Also use on stainless steel rubbing with the grain- this is the one product that truely cleans the surface. Follow up with baby oil or a stainless steel "polish that is oil based to "seal"the surface.
    debrucepolish.com
    Jan 13, 2009 | Maytag MER5730 Electric Kitchen Range
    How do i clean the top of my gemini stove
    Use Baking Soda and water and form a paste. Use this to clean the top of your stove. If food is really baked on, you might also consider using a single blade razor to scrape the mess off. Rinse well.
    Sep 21, 2008 | Maytag MER6772 Gemini Electric Kitchen...
    Kenmore 95592 / 95594 / 95595 / 95599 Electric Kitchen Range Logo
    118 people viewed this question
    Top Kenmore Kitchen Ranges Experts
    Marvin
    Marvin
    Paul Carew
    Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
