SOURCE: Stoves 900GDO Bottom oven door seal
The handbook tells you how to take the door off. If you can do this, do so and then clean/spray all the door hinge mechanisms with WD40. Remove the surplus with kitchen towel and replace the door. Operate the door a number of times to see if this has cleared the problem. (Over time the hinges seize up and the WD 40 normally eases this situation).
(Don't be confused with the air flow coming out of the oven from the cooling fan as this also runs along the top edge of the door).
