Keurig B60 Coffee Maker Logo
Posted on Jan 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Warning of lead in keurig coffeemaker
Where is the lead in Keurig and what are the dangers of exposure?
  • 1 more comment
  • Anonymous Mar 13, 2014
    I don't see the screw on the back of the coffeemaker to get into it.
  • Anonymous Mar 23, 2014
    how to program on time
  • Rather Not
    Rather Not Apr 06, 2018
    Ok so I have a project and I need to know the dangers about this machine. Thank you so much. And hope you have a very NICE day and night. And if I don't get help I'm going to cry and if you read this and move on with this cite IM GOING TO CRY EVEN WORSE BECASUE IM GONNA GET A 0 ON THIS PROJECT, PLEASE ITS A SIMPLE TASK TO TELL ME HOW THE MACHINE IS DANGEROUS, and I'm sorry for using all caps but like I need help so badly. And lowkey I read the answer below and it didn't OR NOR WAS IT CLOSE TO TALKING ABOUT THE COFFEE MAKER.. @DAVID idk what you were thinking but you were talking about pluming on a COFFFE MACHINE QUESTION?! OH my please send the lord and savior upon me and send help. Alright thank you, ya boi is out. Peace.
David Shaub
Level 3:
President:
  • Master 2,994 Answers
  • Posted on Jan 05, 2009
David Shaub
Master
Level 3:
President:
Answers
2994
Questions
Helped
1153520
Points
8370
The solder joint in the tubing. Personally, I don't see a risk but the environmentalists see a risk in any lead at all. The plumbing in my house has ALL lead soldered joints. Now, plumbers are not allowed to use lead type solder. If the water just passes over the lead, there is absolutely minimal chance of problems. Keeping wine in a lead crystal decantor will also leech lead into the drink but, you don't hear all the hype about that. It's all about making the earth green. Toy wagons are being recalled because of lead in the paint. I don't know of ANY kids who ever ATE their wagon.
  • jimh615 Jan 11, 2011
    Any way you shake it...LEAD IS BAD !!!!!!!
  • Anonymous Aug 16, 2012
    No, I don't know of any kids that have eaten their wagon either. However, I can guarantee that there are a lot of kids who have eaten paint chips ffrom anything and everything in their environment! I did when I was a kid (many, many years ago)! In today's world why would any manufacturer still use lead solder in any appliance used for food products? No, one joint in one appliance probably does not create a significant hazard. However, how many other sources are contributing lead into our systems that we aren't aware of? How often do we see warnings on other pieces of Chinese garbage? Lead poisening is a cumulative condition, not the result of one single dose!
2helpful
I put milk in my Keurig and now it won't work...i think the milk burned
..wait..you mean you poured actual milk into the water reservoir on a Keurig coffeemaker..?
That's not good.
What prompted you to do that?
My advise would be to boil water in a kettle, adding about a half-cup of regular vinegar. Pour this into the coffeemaker and let it run through a cycle with just the hot water/vinegar solution. Next, run plain hot water through it.
Hopefully, this will help with flushing out any/all milk that's clogging the coffeemaker. You may have to do this several times to remove the milk residue..milk will cling. (and will start to smell foul..which may or may/not attract insects) so don't ever do that again!
Phoning Keurig Customer and product support may assist you further. They are generally very helpful with all inquiries and issues.
Keurig single-cup coffeemaker
http://www.keurig.com
(866) 901-BREW (2739)
10helpful
"Prime" is showing in the upper right corner of
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Keurig lead and chemicals are they dangerous
Yes, lead is dangerous in any amount. Most chemical are bad in some form or another. Please do more research on this matter. Google is a great search engine. Good luck.
My Keurig coffeemaker sometimes makes only a couple of ounces of coffee and sometimes makes the full cup. How can I fix this?
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Keurig B66 model - "Not Ready" message when I push
heatman101-=-=-
My Keurig coffeemaker will not brew a full cup consistantly, what can I do?
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
1helpful
I have a Keurig B60 coffeemaker. When making a
Descale yes you should every 3 months. Use 48 oz. of white destilled vinager and follow the instructions in your use and care guide
9helpful
Lead in the coffee maker
It does contain a small amount of lead inside a copper coil located in the electronics of the machine. This part does not come in contact with the water, heater or any other part that would cause lead contamination of your coffee.
This page has a great write up explaining it:
http://coffeebreak.today.com/2009/04/08/keurig-lead-warning/
Top Keurig Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
