Why i cant find my hidden folder? I've checked the show hidden folders on folder option and clicked apply and ok, after that, i cant still find the hidden folder.. and when i open the folder options again, it show that, do not show hidden file and folder i think i can't it, how can i recover my hidden folder?
Download that file and execute it. It will do the settings and restarting the explorer
sevenforums com
SOURCE: could not select "show hidden files & folders" in folders option
go to system registry.......click start then run and type regedit then find this key HKEY_ LOCAL_MACHINE software microsoft windows current version explorer advanced folder hidden showall
in your right pane show it DWORD key of CheckedValue delete it.....and create new DWORD key and give the name CheckedValue and enter 1 into value data.......
restart your pc..........
good luck.........
The best earn money site..plz signup free
http://bux.to/?r=jiteshright
(Join now and receive a $0.05 Sign-up Bonus)........click on it........
SOURCE: About folder option
Yes, that's true its infected by virus, if you can install a new anti-virus, and have it scann. If the problem still there use another anti-virus. If you want to view a hidden files even if it's infected by virus just creat a new user in your computer, with that new user you can enable a view hidden files.
Thanks.
SOURCE: about folder option
Click on Start - Run and then type:
Regedit
then go to
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\Explorer\Advanced\Folder\Hidden\NOHIDDE N.
There should be two registry entries there:
- CheckedValue : Type: DWORD Value: 2
- DefaultValue : Type: DWORD Value: 2
(Correct them if necessary.)
Now open the key
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\Explorer\Advanced\Folder\Hidden\SHOWALL .
- CheckedValue : Type: DWORD Value: 1
If the problem persists, open Start, Run, type "regsvr32 /i shell32.dll" and
click OK.
reboot the computer.
thats it, have fun :)
SOURCE: folder option can not show me the hiddne file and folder.
this is a virus for xp user follow these steps:-
go to system registry.......click start then run and type regedit thenfind this key HKEY_ LOCAL_MACHINE software microsoft windowscurrent version explorer advanced folder hidden showall
in your right pane show it DWORD key of CheckedValue delete it.....andcreate new DWORD key and give the name CheckedValue and enter 1 intovalue data.......
restart your pc..........i hope its work fine....
http://jiteshright.blogspot.com/
SOURCE: i couldn't view the hidden files when i apply show hidden files.
Folder Options is removed from Tools in Windows by a virus. The virus is called W32.Rontokbro@mm OR W32/Rontokbro.gen@MM
The removal of this virus is slightly difficult. Antivirus can't remove
it automatically. However detailed procedure to remove it is available
at
http://coolexp.blogspot.com/2008/01/fold...
About this Virus/Worm:
What it does is creating new files which looked like a folder but its
actually a .exe file. Unless you’ve enabled the view extensions in the
folder options or else you won’t see the .exe extension of the file.
The file is approximately 43.7Kb and normally people will click to open
it because it looked like a folder. So after you’ve open it, the virus
will run each time during startup and keep on spreading and spreading…
into the harddrives.
More troubles coming up. Normally when you click “Tools” in explorer,
there’s a “folder options” underneath it. Once the pc is infected with
the virus, the Folder Options will be missing, which disabled you to
change the options to view the extension of the files. So when you see
a new folder appeared from nowhere and you clicked to open it out of
curiousity, the virus spread more again. Moreover, the virus disabled
the registry edit where you will see this message “Registry edit is
disabled by the administrator” everytime you try to edit the registry.
So how to clean the virus then? I found some solution from the following link and have successfully cleaned it from my system.
It will help you to get rid of this virus named W32.Rontokbro@mm aka brontok.a and to get back your hidden files.
Source(s):
P.S.: If this information was helpful, please rate this solution.
GO TO MY COMPUTER THEN CLICK TOOLS >> FOLDER OPTIONS >>VIEW>>THN GET DOWN TO ''SHOW HIDDEN FOLDERS'' THNX FOR SOFTWARES SEE MY WEBSITE www.arsofts786.blogspot.com
it doesn't work... when i close the folder option and open it again.. .. nothing has changed..
