I formated 8gb verbatim pendrive when done it showed 8mb
Click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7 Right click on usb drive select properties you will have an array of options Select the hardware option then select your drive properties policies restore defaults In XP you might have to alternate doing this repeatedly until the problem is resolved
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
then you restore it to its default status
Right click on your drive select properties then on customize restore Default in W 7
click start control panel scroll to folder options view place a tick in show hidden files folders and drives
this may vary depending on your operating system
if you need more help with this post a reply
hope this helps
SOURCE: 8mb vs 8gb of space on an 8gb flash drive
try to copy them again to flash drive use a format flash drive first ok
no it can't solve
