In case something winds up sincerely with your Dell printer, you endeavor to fix it isolated or you go in neighborhood heading which you dependably find excessive and not 100%. Thusly, we brief that you can get called "One Search Point" gave by us. We offer a smart number that you can call and trade with the Dell expert on the phone and discussion about the issue with your Dell printer. Inside a minute, your pressure will be grasped and in case it requires further support, by then you are given that what's more
Dell Printer Support Phone Number.
https://www.onesearchpoint.com/dell-printer-support-phone-number/
SOURCE: Deoo All in One 948 appears to reset continuously
I took my ink into the refill store and she steamed it for me and cleaned it up. It then worked great. It had dried ink and wasn't printing proper.
Try to check for sticky or dried ink this also cause to print intermittently and also not printing.You just cleaned it so it works normal again.
Hope it may help you;
Regards,
VOTIT
SOURCE: Dell 948 wireless printer
hi,
u need to have wireless internet connection, first uninstall the printer sw, while reinstalling choose wireless install, follow inst, connect the printer, configure wireless adapter by choosing the correct wireless nw and by entering the security key(WEP, WPA), if wireless adapter not detected then, unplug all cables from back of printer,removed wirless adapter, press power button for 20 secs without any cables connected, connect cables, restart printer, connect the wireless adapter, u will get msg nw card detected, then try reconfiguring by entering the correct keys, in case if u dont know the security key contact ur internet service provider, once correct details are entered it will configure successfully, unplug usb cable from printer and pc, install printer sw, issue resolved, if there is no communication then check the firewall settings, anything relating to printer give full access, restart pc, try printing,
ps: if usb cable is connected to printer the nw card will be disabled.
SOURCE: Dell All-In-One 948 InkJet Printer
This might not be the issue but I had a similar problem when I first got the printer. Open the top-( where the ink is loaded), look at the back on the right there is a small bus cable ( flat wire usually white) make sure it is pulled in all the way into the top. Be carefull as the prongs can break. This took care of my clicking clacking when the machine came on.
Good luck
SOURCE: Clear Paper Jam message on my Dell 948 nAll in One
press cancel button,, for 30 seconds, it will reset, either, press, on/ off button once.
