So when i try and start it up it takes about 15 times of resetting the breaker to start up . it gradually gets faster and faster everytime until it finally goes . someone has replaced the cord on it i wonder if this has anything to do with it
SOURCE: Have emglo airmate when I turn it on the overload
It could be a couple of things. To me it sounds like you have a short in the motor or damage to the cylinder and piston. You need special equipment in order to test the armature and field for a short. There may also be damage to the brushes and brush holder. There could also be a problem with the cylinder and piston. The bearing could be bad causing a hard start for the motor. I think it could be the combination of the two problems listed above. You may want to check the pump first and if that is not the problem it is an electrical short in your motor in which case you should buy a new compressor. It will cost more to fix if the motor is damage than to buy a new one. "BER" Beyond Economical Repair.
SOURCE: Have an emglo that will not start. Replaced the
may have tripped the overload look for a reset button allot of them have the number 15 on the tip of the button try pushing it in and see if it starts or if it is buzzing when you try and turn it on it most likely is the capacitor
Testimonial: "Did try the reset switch to no avail - no buzz"
SOURCE: I have an Emglo compressor which firers up without
If the in-tank check valve is leaking air back into discharge line from the pump, the motor will not have enough power to overcome headpressure. Easy test with some air in the tank. Remove the discharge hose at the brass check valve at tank. Spray soapy water on valve to test for leak. If leaking remove the valve and clean the seat or replace as needed (drain air from tank before you remove the valve). If no leak at the valve, test the capacitor(should read to within 95% of mfd rating). Good luck
