I have had my Nabi tablet for 3 days now it will now turn on what can I do to fix it??? Please help! It is my sons tablet
You should first verify that it is getting power. There have been some issues with the nabi's charger that you can read about here. While plugged in and charging, the red light should be on, and will change to green when it has finished charging.You should then be able to turn it on. You can download the nabi manual here.
If the battery is fully charged, then the next thing to try would be to remove the battery and let it sit for several minutes. However the nabi wasn't designed for a consumer to do this, so you should email [email protected], or call 1-855-275-6224.
I have just worked on one and the mainboard has to be reflowed if you have no power.
hint * It has an Nvidia chip...duh no brainer
Mine is not doing nothing
None of this worked for my nabi
SOURCE: Crazy Tablet - Genius 8x6
I have same tablet and the biggest problem is USB cable!!!
USB able is made from bad materials and the plastic/rubbery coating of inner wires of USB cable is very easy to brake, then the wires inside of the cable get connected between them selves and all the problem that you have starts.
I had those problems and all was solved by changeing the USB cable.
Changeing the USB is litle bit problematic becous it is connected to the tablet by microconnector that is wery hard to find (for me it was inpocibile). Becouse I couldn't find the matching microconnector I connected new cable to the one on the old cable welding the wires to the ones on the microconector . AND IT WORKED!!!
You may consider to by new tablet becouse this may seam complicated, but for me it was an interesting thing to do and it payed out. Just watch out to connect all the wires properly!!!!!
I hope this was helpful :)
Sorry for bad english ;)
P.S. If you have any problem while doing this write me here and all try my best to give you answers.
Steve from Serbia!!!!
SOURCE: Waco cintiq
I plug it into my pc and everything, in the end it said no sync and it went to sleep, so do you know whats the problem and how can it be solved?
Please and thanks you
p.s: can u explain the unplug power solution with more details, it'll be a pain for my cintiq to break down on me
SOURCE: Wacom CTE-440 Graphire4 tablet is drawing when I don't want it to
Ok so I called costumer service because mine was doing the same thing. Apparently the pressure sensor in the pen is stuck down. What you do is remove the pen tip with tweezers, blow in the open end of pen, then tap the pen (open end down) in a table to get any debris out of there. Then just put the tip back in and give it a try. That did the trick for me. Hope this helps.
SOURCE: Wacom tablet (Model ET-0405-U) Driver?
Hello I am Se7en-Helllas (MaxCeaters user)
For me works GREAT and 100% right, so this is the original wacom's link to download a multiple models driver, including the:
Tablet Blueberry ET-0405-U for Windows XP (32x & 64x)
the link:
http://cdn.wacom.com/U/drivers/IBMPC/pro/WacomTablet_605-7.exe
SOURCE: Wacom Tablet overly sensitive
i had the exact same problems with my graphire4 pen.
take a tool to remove the tip of the pen. just blow inside the pen, put the tip back and press it in back but not too hard. works like magic!
