SOURCE: Magnavox combo vcr dvd
What you're describing is common when the center LED has failed / gone out. If you're really good at taking a unit like this apart and putting it back together - and not too bad with a solder stick you could attempt this one yourself... It is a pretty intensive repair but not difficult for a good shop just time consuming. The part isn't too expensive either, just an infared LED... In fact, we've run a bit short on stock once in awhile and bought one of the off the shelf versions from Radio Shack which worked just fine. Good Luck Bill
SOURCE: phillips dvd player
OK lets start off by getting rid of the CD lens cleaner (CD cleaners do more damage then good). Now first we need to clean that lens with a DVD lens clearner (finer cleaning surface). Try to run the DVD cleaning disk twicw (no more) and try to play a DVD. If this does not work. You may have to test the laser power. get a schematic for the DVD that you have, and use it to let you know the specific power measurement of the power, This is done by using a laser power meter, you may not have one, so this becomes a moot point, but on the off chance that you do, use the laser power meter to measure the laser energy and make sure it is to specs as seen on the schematic. If you do not have a laser power meter., well I hate to tell you this but you may have to get a new unit. See the problem is the process of fixing this problem is simple if you have the right equipment, but if you don't you are at a disadvantage.
SOURCE: magnavox mwd7006 dvd player hookup
How can I hook my Magnavox MWD7006 player up to a entertainment system. So far sound is playing in Stereo (3 speaker) format instead of (six speaker) format or Db5.1. Any ideas? I used a s-video cable to connect.
SOURCE: tuning a samsung tv to a phillips dvd, a goodmans video and an akura freeview box
No le moviste al sistema progresivo del dvd ya que por lo que dices eso puede ser la causa.Si el control del dvd tiene una tecla con ese indicativo presionala para eliminarlo.
